"Rock Its" Build Thread
  • #76
    Re: "Rock Its" Build Thread
    Originally posted by davepellegrene View Post
    Tried to get a close up to see the depth of the grain. Seems the flash is what messes it up. I will try some outside shots tomorrow.
    • #77
      Got a couple coats of Polycrylic on them. I am going to bring them in and start measuring one cab at a time and start putting the pour on epoxy finish on the other one. Hope that goes well. :rolleyes:
      Dave
      Pic doesn't do them justice. Very nice deep rich look to the finish.
      Looking great Dave! I like your stain choice, it really makes the stainless pop. :eek: I've used that same bronze metallic on a small table with a few coats of clear poly semi-gloss, it really gave it some depth. BTW, I see a fork lift in your future. :D
      Dan
      • #78
        Great job man!! Those things are just over the top!
        A mains
        The Ventures
        Open Invit8tions
        RSR
        Sound Troopers
        Acorns
        442
        DGBG's
        The Monuments
        • #79
          Wayne,
          The wood I used I believe is black walnut. It was left at my house when I bought it. As far as these being the big brother to the Nightmares I guess you could say that. I always liked the look of the Nightmares from the back so that is were the design started from.
          Dan,
          I was wanting something close to burgundy for the wood almost a plumb color. Didn't get quit what I was after but I am happy with it. After seeing the wood sanded I was afraid to go to dark and loose to much of the grain. It does contrast with the stainless nicely. I was in hopes between the dark baffle and cabinet the stainless would stand out.
          6th planet,
          I was really trying to keep them simple with simple lines but with some interesting angles.
          I did manage to get the drivers in and the baffle on today. Ran into a snag. I couldn't get to the center set of bolts on the baffle, that screw on with a nut from the inside. So I had to drill a hole big enough for my hand to go through in the center divider of the TL. I guess I will just screw the plug back in when I'm done.
          See the nut through the hole just above the driver. Had to many braces in the way to reach from the bottom. Figured even if I could get my hand up in there I would drop the nut or washer into the basket of the driver anyway.
          If the sun shines tomorrow I will take one outside and get a better shot of the metallic bronze on the baffle.
          I used weather stripping foam between the baffle and the drivers and between the baffle and the cabinet so it isn't in contact with anything. I was concerned about vibrations.
          Dave
          Trench Seam Method for MDF
          • #80
            Those are absolutely gorgeous! What a cool design and you sure pulled it off, congrats ...
            That weather stripping will compress quickly, and after just a month or two will provide essentially 0 vibration barrier. Once you get them finalized and ready to button up for good, I'd suggest pulling off the striping and try something called Green Glue ... google it. I've used it a couple times now and pulled a baffle off that had it applied for over 2 years, and it was still the same consistency as new. It's designed for use as a shear layer between sheets of drywall, and for that use must remain consistent for years and years.
            Vapor Audio
            • #81
              Dave- they're stunning!
              I can't wait for a better lighted pic!
              Hope to hear them soon.
              • #82
                Very nice! What is your take on that TB 4" mid?
                • #83
                  Sounds like a good idea if I can get the baffle back off. The only way to get the drivers out is by removing the front panel. The glue would be sandwiched between two layers of the roofing membrane and from experience nothing sticks to well to it so I may be ok with it.
                  Thanks Dave
                  • #84
                    Took them out yesterday but I couldn't get any direct sun light on them without carrying them all the way down to the lake. Way to heavy for that!
                    I can't wait to hear them myself. I have them next to my Mini's, that are very solid cabinets, and I noticed doing the knuckle test against them the rockets have a completely different sound. Different then any I have built yet. Should be interesting.
                    Dave
                    • #85
                      I don't know. I haven't hooked them up yet. They sure do look like a solid driver.
                      Dave
                      • #86
                        Here's a couple outside pics. Still couldn't get very good shots the sun went back in so I had to give up. The better light does show the glue, I didn't get off yet, finger prints and dirt a lot better. :rolleyes:
                        I am convinced that I want to coat them in the epoxy finish now. They just seem to me they need to be high gloss. Except maybe the baffle I kind of like it with the semi gloss finish.
                        Dave
                        • #87
                          Looks good!
                          • #88
                            [QUOTE=davepellegrene;1657147]Here's a couple outside pics. Still couldn't get very good shots the sun went back in so I had to give up. The better light does show the glue, I didn't get off yet, finger prints and dirt a lot better. :rolleyes:
                            Dave
                            Dave, the speaker looks really good. I like the look you got going now, more in the wood sheen. If you do the epoxy, won't it look like glass or plastic on top of the wood? Also, the beautiful dark wood grain contrasts nicely with the shiny metal. I wonder whether a glossy coat on the wood might lessen the nice contrast. Just some thoughts..... Darren
                            • #89
                              Thanks Darren. When I started this project I had envisioned a shinny finish. After seeing Jim Salks Soundscapes I really liked the high gloss. To me it adds to the depth of the wood. As you can see with his finish it has good contrast to the woofers cone which is real similar to the stainless on mine. After looking at this pic I hadn't realized how close I came to the color of his. Wonder what he used his seems to have more red then mine and that's as red as I could get without going to a dye, which I have never used. Could be the low lighting. Mine take on more of a red cast inside.
                              • #90
                                Could be the white balance of the camera too. Nonetheless, they are stunning, you should be proud. Hope they sound as good as they look.
                                Steve
