"Rock Its" Build Thread
  • #91
    Re: "Rock Its" Build Thread
    You are right Dave. The Salk speaker was meticulously finished. If you are going for that look, then I think they will look good. Whatever you do will end up looking good. You're one of the many wood whisperers on these boards!
    Darren
    • #92
      That's an excellent way ("wood whisperer") to describe Dave's wood-working skills. I'm always envious of his work.
      Paul
      Darren
      • #93
        Paul
        Thanks guys unfortunately my skills are coming to a quick end as I start into the real parts that make a great loud speaker. I will probably be needing some advice on the TL as soon as I get things properly set up. Paul, in one of your emails you said to stuff the line .75 lbs. per sq. ft. and to stuff the first 26". So if my line is 7"x7" then add the 26" that makes .74 cu. ft. so that converts to 12oz. of stuffing correct? All I had was 7 oz. of pillow stuffing so I put it in. As of now measuring with arta the woofer is rolling off around 50 Hz and I have a few decibel hump at 125 Hz then about a 4 db dip around 400 Hz. Am I correct in assuming the early roll off is the port and the hump and dip is stuffing. I also did not break the woofer in at all I just hooked it up and took measurements. I was working more on getting my set up correct. I haven't taken any Impedance measurements yet. Not sure if I can even get any accurate measurements inside either. See what I meant about my skills coming to a quick end.
        Dave
        Trench Seam Method for MDF
        • #94
          Hi Dave,
          What did you do for the dye or stain, Dave - or did I miss it?
          Maynard
          • #95
            You would need ~9 ounces of stuffing uniformly distributed by weight in the first 26" of the line's total length to achieve a uniform density of 0.75 lb/cu.ft. within that 26" length. Regarding your measurements, the email I sent you on May 3 had several graphs. The second one shows how the woofer should be responding with the red line, and how the port should be responding with the dashed blue line. The woofer's response actually starts rolling off around 200 Hz and will be 8-10 dB down at 50 Hz, with a notch at 40 Hz which is the system tuning frequency. The port's response peaks at just above 40 Hz. The third graph shows the impedance characteristic. If you no longer have that email I should be able to resend it.
            Paul
            Dave
            • #96
              Originally posted by maynardg View Post
              Hi Dave,
              Maynard
              I used Min Wax Red Mahogany.
              • #97
                Paul
                I have all the emails I will go back through and find those thanks.
                • #98
                  Just to simplify the stuffing requirements, you need approximately 1 ounce of stuffing in each 3 inches of line length for the first 26 inches. When you go back and look at those graphs sort of represent a "perfect" driver, one whose response is absolutely smooth, which obviously ain't never gonna be true.
                  Paul
                  • #99
                    I must have the density correct. I have 7 ounces in 20 inches. That is to the bottom of the line. If I turn 90 degree do I then make the next 6" from the center of the line. That would go to about the center of the next 90 degree turn. Or am I over complicating it. Just put the next 2 ounces on the rest of the bottom towards the back before it turns up.
                    Here is my measured impedance. Looks like it is tuned to 45 Hz. I believe it should be 40 Hz. Wonder if this is because of the flared ends on the port. Should I lengthen it to lower the tuning? An inch maybe? Can a lack of stuffing cause this?
                    Dave
                    • Re: "Rock Its" Build Thread
                      The ends of your port are rounded over more than they are flared, but the roundovers will have the same effect as being flared just not as much, so you will need to lengthen the port. How much I don't know but an inch may just do it. Stuffing has a small effect on the tuning frequency and since you have less stuffing than I modeled with, the tuning frequency will possibly be a little higher than desired.
                      Paul
                      Dave
                        Paul
                        I'll go ahead and get the rest of the stuffing before I do anything with the port.
                          Got a bag of stuffing today. I decided to pull all the old stuffing since it was a little different from the new stuff. It's kind of nice stuffing the line with the three inch hole that I had to cut though the center divider of the line so I could access the screws on the baffle. Then it dawned on me. this is were I need a smiley of a light bulb. I forgot to put the plug over the hole in the divider when I closed up the cabinet.
                          I did a new Impedance test with the modeled amount of stuffing and the hole plugged and I got an almost identical graph as what Paul modeled. Even the peaks on the double humps match.
                          Dave
                            Oops!:p We all have done something similar, like wiring one driver of the two in an MTM with reverse polarity, and not being able to understand why there's no bass to speak of.
                            After correcting your oops, you were able to confirm this: Using Martin's worksheets, if your model is accurate and you build what you modeled, you will get the predicted results! What kind of stuffing are you using?
                            Paul
                            Dave
                              Paul
                              100% premium polyester fiberfill from Walmart. Is this ok or should I buy something else?
                              Thank Dave
                                The Walmart polyester fiberfill is just fine. BTW what is the length of the port representing the impedance measurement you made most recently? Is it the length I modeled or have you increased the length?
                                Paul
                                Thank Dave
