Nice curves... - Scan-Speak 15M/4624G
  • Nice curves... - Scan-Speak 15M/4624G
    I decided to measure a driver I'd had sitting on my shelf for a while...
    here's the FR taken from about 1 foot with a inductor + cap low pass filter.
    You don't often see such smooth curves as that without notch filters!
    Re: Nice curves... - Scan-Speak 15M/4624G
    Gotta love those ScanSpeak cones and suspensions!!!
    The red curve is the 15W4831 (OEM 4531) on-baffle, sans XO. smooooooth
    Yellow is the RS28A on baffle sans XO.
      If that isn't a drool worthy driver, I don't know what is. All that for only $62 each, this is one of the best looking midrange divers I've seen. This one and the 10F as well. This 15M claims to be 2.5dB more sensitive than the 10F though, which can be very advantageous for anyone wanting a real "loud"-speaker.
        Everybody else saw: "foam surround" and decided to pass, I saw "foam surround" and I thought to myself: "ah, this driver is going to be good...".
        Ha ha Pete, mine's flatter and only cost 1/3 as much :D Mind you, I would like to try some of those Scan-Speak slit paper cone drivers someday...
        I cut out below 200Hz because the floor bounce cancellation was naaaasty. I should try measuring from an extension off my 2nd floor outdoor porch maybe. The inductor corrects for a slight rising high end, but no "BSC" in the traditional sense. That measurement is taken with the driver on my enclosure, not on a test baffle ;)
          I've got no problem with foam surround as long as it withstands the test of time. Visual appearance is another thing of course. This driver, even with the foam surround looks pretty damn sexy. I haven't seen it in person, but it looks like they've color matched the foam to the cone pretty good.
            Ha ha Pete, mine's flatter ...
            You think? Check scale . . . mine's on a 5dB/div, yours is on 10dB . . . ;)
            Same here, on the Byzantium baffle.
            You can be sure that I'll be using those Discovery mids in a future endeavor. :D
              Nice, beefy frame too.
                Flatter, yes, smoother, perhaps not. Now, with two crossover components, you might match the flatness, but will you have a design that doesn't need BSC?
                  Yes!!! Just use a real woofer to fix the baffle step problem!!!
                    Thans for sharing... I've had my eye on that one for a future project.
                      Hi,
                      This no follow up of this driver because no one that I know of have use this driver in their design. I am thinking of using it instead of the Discovery 10F which I understand is being used by a few designer incl. John K. This driver(4624G,92.4dB) has better sensitivity compared to the 10F(89dB).
                      Is there anyone out there who can contribute their knowledge on this driver confirming what Critofur had obtained?
                      Thanks in advance.
                        Nothing wrong with foam. I noticed the foam surround when they first came out. That's a big part of the smooth response, I'm sure. The 21W/8554 used it, I've got a pair purchased used. They still look new. As a treated foam, they should last, from what I've read, maybe 30 years. Yet there are frequently those who post that they won't use a driver with foam because of a preconceived notion of it being inferior.
                        SS has been making drivers with foam that last 20-30 years for a very long time.
                        dlr
                        Dave's Speaker Pages
                          Hmmm. Nice woofer. Would like to see some distortion measurements.
                            Here's the 10F from Zaph's blog. I've no doubt the 15M would be similar, if not better. This is superbly clean midrange performance.
                              I would bet the HD would fall somewhere in between that and the HD of the 18W8434 seen below since the 10F has a copper cap and this one only has an aluminum shorting ring. Now that is still a great place to be for a midrange under $100, much less the $55 this one goes for.
                              Chris
                              Chris
                              Goofing around since 2000.
