Maple Veneer and Finishing - least problem with blotching
  • Maple Veneer and Finishing - least problem with blotching
    Seeking ideas and knowledge.
    I'm considering maple veneer for the current build. Ideas on the veneer cut (flat, rotary, quarter, etc.) least likely to appear blotchy.
    Also ideas on how to finish to avoid blotching.
    Thanks in advance!
    Maynard
    Re: Maple Veneer and Finishing - least problem with blotching
    Well, one way is don't stain it. If you need to color, spray on water/alcohol dyes are usually the easiest to keep even. Dyes in thin shellac, padded on, are also doable. Quarter cut should be less problematic than flat cut or rotary cut.
    Lou's Speaker Site [speakers.lonesaguaro.com]
    "Different" is objective, "better" is subjective. Taste is not a provable fact.
    Where are you John Galt? I may not be worthy, but I'm ready.
      You can also try a wood conditioner before applying your stain. It helps in many instances, especially when staining veneers and plywoods.
        waterbased gelstain.
          You may want to read this first on wood conditioner. The article is down the page a little on my screen.
          http://www.popularwoodworking.com/ar...ner_Confusion/
            You saw my Sonatellos which have maple veneer and solid maple (as well as solid walnut and veneer). I didn't stain either and applied 2 coats of Zinsser Sealcoat before applying several coats of satin wipe-on poly. Both the Sealcoat and poly had slight tints even though both are labeled as clear. Oh, the veneer for both woods was 1/64", paper-backed, PSA veneer from Rockler.
            Paul
            Thanks in advance!
            Maynard
              thats good advice... besides, I would not color maple anyway unless it was plain and unfigured. however the die will make the figure pop but so will a half a dozen un colored methods as well...
              Mark
              http://www.diy-ny.com
                Ok, I'm convinced. No dye or stain. Any favorites for a finish?
                  I did. If you read his solution it is what I've always done, and that's to let the conditioner fully dry before applying stain. It works well.
                    Maple isn't prone to blotching like cherry for example.
                    It is difficult to color. Dyes work best, they penetrate. Pigments tend to wipe right off, especially on very smoothly sanded maple.
                    Any topcoat should work fine.
                    A very light color dye will help accentuate grain and figure under any topcoat.
                    To preserve the "whiteness" choose a WB acrylic or acrylic lacquer that has not been formulated to amber.
                    All other finishes will darken, some more than others.
                    Thanks in advance!
                    Maynard
                    ~99%
                      I like poly/oil finishes...
                      Mark
                        Don't overlook the value of block sanding to the finer grits before you get to the finish coat.
                        150?
                        280? :rolleyes:
                        400? :D
                        Mongo only pawn in game of life
                        ____
                        Ed
                          Paul
                          Maple has a tendency to yellow over time anyway. Paul's schedule will work well. You might try cutting the Sealcoat 1:1 with alcohol for a small batch. Add a drop or two of Transtint dye (medium or mission brown). Wipe it on quickly, then let it dry. Sand with fine grit to remove the top layer of shellac, then follow with another coat of sealer. This will leave a bit of dye in the pores, without a drastic color shift -- accentuating the figure.
