My RS180 MTM Design
  • #31
    Re: My RS180 MTM Design
    Originally posted by Jeff B. View Post
    No, it is not. The crossover would have to change slightly. That was why I was hesitant to post this, but several people sent me emails asking me to anyway. With the current version there would likely be a small dip in the crossover range. Increasing the first cap a little should smooth that out though, but I haven't done any work with that combo to see, and since I don't have these drivers anymore, I can't do that right now. Some people might like it better with the dip. It would only be a couple dB.
    Jeff, sorry to be so dense, but by first cap, do you mean the 10 or 50uf? And as a place to start in increasing the value are you thinking a 10% or 20% change? Thanks
    • #32
      I mean the 10uf, and I mean taking it to around 13uf for a starting point.
      • #33
        Jeff,
        I noticed in your profile that these speakers have their own plate amp's,
        I am keen to know who built these and how many watts they produce.
        Thank you.
        • #34
          Jeff, how are these on the SPL side and low end extension compared to the Statements Monitors? I'm having second thoughts about those and their ability to integrate well with my 15" sub.
          Modding the Lepai T-Amp
          • #35
            To be honest, I don't know what Statement monitors are, so I can't make the comparison. However, these crank pretty nicely, and blend very well with the sub in a pretty large playback room. Two 7" woofers move as much air as a 10" woofer, so they keep up OK.
            • #36
              http://speakerdesignworks.com/Statements_Monitor.html
              I'm questioning whether or not the statements will give me the output I want with my sub when they only have one of the RS180's and your design has two of them.
              • #37
                Originally posted by Hunter12 View Post
                Jeff,
                Thank you.
                No, the design I posted is passive design. There is no amp with these. I built an earlier pair that was first powered by the MCM Biamp plate, but just didn't have enough output, so we stole the amps from a pair of Behringer B2031A's to power then with. Again, this project that I posted is all passive.
                • #38
                  Depends on how loud you want to play them. I would think mine will have higher power handling. And they will hit +6dB more output in the low end due to the extra woofer.
                  • #39
                    Thank you.
                    • #40
                      Jeff;
                      You asked if I have an amp that will handle 4 ohm speakers. It's an RX-V3900 Yammy which I think should be able to do it. I would place a center channel below my screen in a piece of furniture I am designing, it would have a shelf/pocket to accomodate the speaker cabinet, essentially placing it in a pretty large baffle (the furniture and the monitor surrounding it.) The speaker would be about listening height or a little below. Since the crossover is pretty low and 4th LR, from what I've read, it should work ok as a center.
                      Once again, thanks for your valuable input.
                      Steve
                      • #41
                        Jeff,
                        That tweeter is out of stock. Can it be substituted for the RS28A-4?
                        • #42
                          Jeff,
                          He answers that question in post #11.
                          Chris
                          Chris
                          Goofing around since 2000.
                          • #43
                            Here's the on-axis frequency response with the reverse null shown (for those that like that sort of thing...)
                            Jeff,
                            Does that curve indicate the system sensitivity to be about 90 db?
                            When xover FR SPL curves are plotted on this type of graph, does it always indicate system sensitivity?
                            Thanks,
                            Marv
                            • #44
                              Originally posted by marvin View Post
                              Jeff,
                              Thanks,
                              Marv
                              In this case, yes, 90dB.
                              • #45
                                Jeff,
                                Thanks,
                                Marv
                                In this case, yes. I use one method to measure sensitivity and another to measure the response, then I normalize the response to the sensitivity. Of course, not everyone's simulations are done this way, so you can't always assume.
                                Jeff
