Removable Baffle Gasket Material
  • Removable Baffle Gasket Material
    I am doing removable baffles (for the 1st time) on ready to assemble Nano Neos. What do you guys recommend for gasket material?
    Thanks!
    Audiophiles listen to the equipment, not the music.
    Re: Removable Baffle Gasket Material
    PE's driver-gasket-tape is a good product for it. I used it on my mule-boxes to seal the Glucinium Amor baffles.
    Either that or the weather stripping from your local Walmart, or even adhesive-backed-Foamie from a craft-store.
      Basically, all my builds have removable baffles, and I've always used self-stick weatherstripping. As far as I know, the minimum thickness you can usually find is 3/16 inch, which leaves your baffles a bit pulled away from the boxes, even after you've screwed them down. In the future, I'm going to try a thinner foam for this use.
      Tangband W6-sub
        Pretty veneer. Consider RTV rubber sealant. It seals and squeezes out. It will have to be removed each time you remove the baffle. I used it on my Madisound RBRs. It's the only thing holding the baffle on, besides a good tight mechanical fit with a two layer baffle with the inner layer fitting inside the box. If I ever want to remove the baffle, I will have to remove the woofer and knock it out with a mallet.
        Good solution if you're not a speaker tweaker.
          I've used play dough before for a small speaker
            I haven't tried this, but I'll bet that the rubber sealant or a caulk could be applied to either the box lip or the baffle, then covered with "saran wrap" for a complete seal without the two pieces getting stuck together permanently.
            Tangband W6-sub
              i bet duct seal will work great. I use it to fill small holes in my car door. its rubberized butyl so itll have some characteristics to absorb some vibrations as well. sure is cheap enough for about $2.50 a lb!
              http://www.lowes.com/pd_13591-12704-...0051&langId=-1
                Mcmaster-Carr carries a number of different types of foam in various widths and thicknesses. Probably the best stuff would be the 1/16" silicon foam with adhesive backing, part number 5109K14. A much cheaper solution would be the rubber-based material: part number 8694K113. Just use the link below and work your way through the selection guides
                http://www.mcmaster.com/#foam/=cy1dbn
                  Ditto for McMaster-Carr for finding thin foam weatherstripping. The stuff I bought last time compresses down to nothing so there's no foam showing and no real gap.
                  I used their part no. 93675k11 (1/8" x 1/4") vinyl foam tape for my last build.
                  Just mount it inside the edge about a 1/16" so it doesn't squeeze outside the joint when bolting the baffle on.
                  Bill Schneider
                  www.afterness.com/audio
                    Thanks to all for the tips. I tried the craft foam because I had it handy, but the gap is too large when compressed for my taste. I will try the other suggestions.
                      felt from a fabric store. use a spray adhesive to attach it to one surface.
                        That would probably work. Most silicones won't stick to masking tape either. I've used that trick on other things where I want a seal but don't want it sticking to the actual item.
                          Thanks for the link!
                          I knew McMaster-Carr carried every material under the sun, just never thought of looking there for the kind of weatherstripping I knew I needed. I think I'm approached the time of life when youthful exuberance at acquiring new facts meets the "leaky bucket" mind in my head.
                          Tangband W6-sub
                            Slightly different topic, but I don't think people realize that they also carry a great selection of felt. Just about any SAE Grade, thickness and size that the speaker builder might need:
                            http://www.mcmaster.com/#felt/
                            BTW, just about everytime I order from McMaster-Carr the stuff arrives the next day. They are in NJ and I'm in VA, which isn't that far, but still...great service
                              Heh, I'm well into the leaky-bucket stage myself. It only gets "better" from here!
                              Bill Schneider
