Panasonic WM60AY electret capsule
  • Panasonic WM60AY electret capsule
    http://www.speakerbuilder.net/web_fi...diymicmain.htm
    ... OOS / NLA from Digikey,
    http://www.digikey.com/us/en/cat/cat...9926?ref=61790
    Very few results, only 1 and it didn't look credible, on google. :(
    Alternatives?
    An apostrophe with an "s" does not mean plural.
    Speaker's IS NOT PLURAL.
    Re: Panasonic WM60AY electret capsule
    Better one : http://www.digikey.com/scripts/dksea...eywords=wm-61a
    Read here : http://www.linkwitzlab.com/sys_test.htm#Mic
    9 out of 10 British housewives can't tell the difference between Whizzo Butter and a dead crab.
      Icor, I have a micro-miniature soldering station, and I'd be happy to attach leads to the back of the Panasonic capsule for you for free. I have a Matsushita (Panasonic) 8mm capsule with attached leads I'm playing with in Speaker Workshop, and it seems to work very well. You know the feeling when something you've built works TOO well?
        Thanks Whitney, I'll keep that in mind if I can't get it.
        I only need to add electronic components if I want to measure high SPL, right?
        Otherwise, it's just solder on the leads, put on tubing/etc, and connect to a minijack?
          I have a couple of those capsules and generally speaking you need to build the preamp to use it, as many soundcards are incompatible.
            What if I just buy this?
            http://www.amazon.com/Behringer-802-...9472737&sr=8-1
              Originally posted by icor1031 View Post
              You would need to use Linkwitz's (or other low-voltage) preamp. The Behringer has Phantom power (48V) for mic's that require that, but that is way too much voltage for your average, small electret condensors. The WM61's are rated for 10V max.
              SEC DIY 2014 Speaker Show is on! *November 8th*
              Wanna win a set of Newform Research R30 ribbons?!?!
              SEC DIY 2014 Thread
              SEC DIY 2012 Speaker Show
              SEC DIY 2011 Speaker Show
                I just posted a great link to a diy mic based on Linkwitz's mic for the Panasonic mic capsule a couple of days ago. I believe I posted the link in a thread called "wt3 problem" or something like that. Or you can just search avs forum for "Lilmike's mic".
                It's a great pictorial and the schematic has a couple of mods and is way easier to read than Linkwitz's chickenscratch hand drawn schematic.
                Don't even try
                to sort out the lies
                it's worse to try to understand.
                  Thanks for the link. That's a very reasonable price.
                    Curious, what would I pay for a mic of about-equal quality? (( Never mind, I found it. I was searching for the wrong thing: http://www.parts-express.com/pe/show...number=390-801 ))
                    http://search.digikey.com/scripts/dk...eywords=wm-61a
                    I may be buying them soon. I'll probably post again about aesthetics.
                      So simple even a caveman could build one
                      http://zobsky.blogspot.com/2008/02/f...with-arta.html
                        Alternatives?
                        I have some capsules and a bare mic preamp PCB I bought from Mad About Sound I'd be willing to part with. Send me a PM!
                          Thanks for the offer mate, but I'm looking at building 6 or more of them.
