The idea is a low profile horizontal MMTMM center, that would match to bigger L/R mains based on the RS line.
I've never tried a 2.5-way before, so this is my first run at it. Frankly I'm not sure if this is the best way to model it in PCD. Using the baffle below and planning for a horizontal MMTMM (using Zaphs measurements), driver CTC spacing suggests an Xover point to the tweet at 1500Hz or lower. The outter pair of RS100s must not play above 800Hz or so.
23"x5.5"x12" (~.6cuft with 1/2" mdf) sealed and stuffed cab is looking good for an HPF at 80Hz, perfect for a center channel. A little bigger & vented and it can go lower but that's not really necessary.
