Possibly new cabinet idea
  • Possibly new cabinet idea
    So a couple years ago we tore out some nasty carpet and crummy linoleum in the kitchen/dining room and replaced it with tile. We did the research and did 420 square feet of tile ourselves.
    Anyway, the process of preparing the floor for tile was interesting to me. On top of the 3/4" OSB subfloor, I put down mortar and then covered it with 1/4" cement board and screwed it down with a (large amount) of special screws. On top of this goes more mortar and then tile, and finally grout. The idea is that the cement board layer is very stiff (and heavy, I might add) and reducing flexing in the subfloor, especially around joints.
    So anyway, had this idea for walls and back of a speaker cabinet.
    Start with 1/2" baltic birch or OSB. You'd have to build the whole cabinet complete with internal bracing before the next steps. Slather on the mortar, attach and screw down the cement board, tape the joints, etc. You can finish this off with more mortar and tile. Any type of tile- slate, polished granite, marble, etc. It could look pretty awesome I think, especially if you did good work on the tile. I think our tile was 3/8" thick porcelain tile, very strong and heavy.. very heavy. I think 10 tiles (10 square feet) weighs 26 lbs. So anyway, with 1/2" OSB or plywood starting out, you are talking a minimum of 1.25" thick, but probably more like 1.5" thick.
    It would be very heavy, very stiff, and could look fairly slick. It wouldn't be that expensive either. You could do any number of interesting things for the front panel, including solid granite.
    -Dan
    Mandolin Curved Cabinet Floorstanding; Dayton Reference 18" sealed Subwoofer; Sealed 12" Dayton Reference Subwoofer ; Overnight Sensation builds
    Re: Possibly new cabinet idea
    Interesting idea. I like it...
    ... but I might be worried that the mortar would develop cracks over time from the constant vibrations.
    I don't have enough experience with tile, mortar, grout etc... to make an informed decision on how it would hold up in the long term. Does anybody else have experience in this regard?
    One more question... would this be considered a variation of the "constrained layer damping" concept?
    ~Marty
    Baby Eidolons
    Sapphos
    Cables (Post #54)
    Other speakers (Post #21)
    Design Thoughts (Posts: 6,10,13,33,35)
    Boundary Augmentation
    Dispersion/Interference
      I forgot to mention a part of my "idea". You would want to use the polymer-infused mortar, sometimes called "Flexbond" which is much more crack resistant.
      Such as this:
      http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051
      I think the 1/4" cement board comes in 3x5 sheets for $8. A huge bucket of cement board screws is $20. Thinset/mortar is $20-30 for a huge bag. Marble, granite, and other interesting tiles in 12x12 size are $3-8 each. Grout is pretty cheap.
      Cutting tile can be interesting- made much easier with a good tilesaw and a good blade. I'm not positive what the process is for cutting solid stone tile since I didn't do that.
      Cement board in and of itself is an interesting product. It's got fibers in it, possibly fiberglass. It's stiff but not invincible, it's somewhat brittle.
      -Dan
        There are already a lot of "constraint layer" constructed enclosures around TT. Look for BillSchu's MOAB. The bass section began with MDF, then was completely lined with mortar then ceramic tile. Very nice enclosure design if I do say so myself.
          I know Rudy Jakubin has used concrete backer board for internal wall treatment. The extra mass really deadens the walls.
            I would skip the "slater of mortar" step. I believe the cement board comes in different thickness, use the thick stuff (1/2 or 3/4)". I would glue and screw the cement board to the cabinet.
              Bob Brines uses backer board in his cabs.
              http://brinesacoustics.com/Pages/Art...struction.html
                Actually, replace the "slather with mortar" step with application of roofing repair film to form a classic CLD sandwich. Then cross-brace to the tile / cement board. Works very well for me!
                HAve fun,
                Frank
                PS remember, no one can see the tile inside, so pretty cuts are optional
                  I bet they'd make a great match as bathroom speakers. :D
                  One can go to great lenghts to dampen cabinet resonances. Just look at the early B&W matrix cabinet designs. At some point, however, the law of diminishing returns prevails.
                  Live in Southern N.E.? check out the CT Audio Society web site.
                    Aren't there some designs out there that call for things like asphalt roofing tiles to line the insides too?
                    -Nate
                      Pink Stucco speakers. Sorry, it just jumped into my mind.
