Please take a look at my 2.1 room response measurements
  • Please take a look at my 2.1 room response measurements
    After a long series of adjustments/measurements, here is what my room response looks like:
    I have my AVR crossover set to 80 Hz, but the crossover dial on my Dayton plate amp rolled all the way down to 40 Hz. Sub response is in green, mains in orange, and summation in blue.
    The spike @ 45 Hz is present no matter what I do. There appears to be lots of room gain below 100 Hz; I tried setting the AVR to 100 Hz, but that sounded anemic to me.
    Any thoughts or suggestions? Things sound pretty good! but my understanding of how to set everything up is still a work in progress
    Re: Please take a look at my 2.1 room response measurements
    I wonder if that spike is simply room nodes coming into effect. Possibly moving the sub may reduce it some.
      I'm not an expert by any stretch of the imagination... but I was thinking that your AVR is already filtering at 80 Hz... would it be better to not crank the Dayton's filter down to 40 Hz? Cascading multiple filters? Possible issue?
      What happens when you turn the Dayton's filter all the way up and rely on the AVR to set the corner freq at 80Hz?
      I'm just brainstorming with you... not sure that this is the correct direction to take, but it won't hurt anything to try it.
      ~Marty
      Baby Eidolons
      Sapphos
      Cables (Post #54)
      Other speakers (Post #21)
      Design Thoughts (Posts: 6,10,13,33,35)
      Boundary Augmentation
      Dispersion/Interference
        Yep, I've tried it, and discovered that my AVR low-pass filter isn't very steep:
        The three traces are three settings on my Dayton 240watt plate amp: blue is all the way down (40 Hz); green is halfway (~110 Hz); orange is all the way up (180 Hz).
        Here is a comparison between the full responses using the 40 Hz (green) and 180 Hz (orange) settings:
          That's what I was thinking, since it seems to be present regardless of setting or adjustments.
          I haven't played around much with room placement -- mostly because I want to keep it hidden and out of the way in the corner (our room is pretty small).
            Did you measure the mains alone?
              Consider moving the couch forward by a foot.
              Anyways, disable the built in HPF, you want overlap. It's extra headroom that can be equalized down. Set the AVR crossover to 100hz. lower the sub TRIM level by around 6-10db. Then measure and listen, of course.
              :blues: Flat frequency response, a smooth sound power response free of resonance, careful driver-integration, and high dynamic range both upward and downward :blues:
                can you describe your room? what are your mains? 3-way ect? where exactly is your sub?
                  Are your mains set to large? Try small with the dayton LP set to full. Then the avr will be doing all the crossing.
                  https://www.youtube.com/channel/UCm2...oSKdB448TTVEnQ
                    Unfortunately, not an option :( Our living room is really small.[/QUOTE]
                      Mains are my Gila 28 design (2-way, 831735 + RS28A).
                      Here's a drawring of our (cramped!) living room:
                        I'm not sure if my AVR has this option, but I'll check.
                          That's almost certainly a room node. Whenever you have a single frequency issue, do the math. In your case: 1127/44hz = about 26 ft. Dominant room nodes are usually equal to the longest clear diagonal in the room. I'm guessing that your kitchen adds another 10 feet to the back wall length. That would make the longest diagonal = SQRT (13^2 + 23^2) = about 26 ft. Is that the case? If so, the only way to get around it is to equalize the peak out or try a much different position for your sub - perhaps to the right of the couch.
                          -Bob
                          -Bob
                          The PEDS 2.1 mini system
                          My A7 Project - another small desktop speaker
                          The B3 Hybrid Dipole - thread incomplete and outdated
                            I think it looks fine as-is, and 45hz peaking can add a lot of free visceral impact to movies, and it looks like your mains are capable of enough extension on their own to enjoy most music.
                              Bob, you have some spooky math skills! My tape measure confirms your prediction -- kitchen wall adds *exactly* 10 more feet of length to the back wall
