Q on Diffraction and Boundary Simulator
  • Q on Diffraction and Boundary Simulator
    Hi,
    Let's suppose I'd like to model the floor boundary effects of a TMWW or TWWWW configuration. How would I do this in the Diff and Boundary Sim toolset?
    My current thinking is to model each woofer separately noting the change in baffle diffraction and floor boundary effects as woofer distance from floor changes. Save each driver off to a separate FRD file. But then, how do I combine these in Response Modeler? I'm not seeing an obvious way.
    For PCD, should I then treat the WWWW as one driver (located where?), or import the separate FRD's directly into PCD?
    Is this an acceptable approach, or is there another I should be considering?
    Thanks,
    Rob
    Re: Q on Diffraction and Boundary Simulator
    Originally posted by weinstro View Post
    Hi,
    Thanks,
    Rob
    Simulate each woofer pair (upper and lower) at their geometric center and save off the FRDs.
    PCD will let you import individual FRDs for the woofers
