Just wondering how much I can brace a TL. This will just be for a 6" woofer. But after hearing Wolf's RS 125 build. (sorry in never remember the names of speakers.) I am wondering if a very well braced, or deadened TL would help. Or would it just mess up the TL tuning. I can have the box and bracing cnc cut, but I don't want to shoot myself in the foot.
How will bracing affect a TL? Is it needed?
Re: How will bracing affect a TL? Is it needed?
A bracing system of crossed ( perpendicular ) hardwood dowels is effective and unobtrusive."Not a Speaker Designer - Not even on the Internet"
That was Wolf's Stance that used the RS125, and hearing that speaker has also made me lust after an extremely dead box. I've heard the RS125 before and it has NEVER sounded better IMO. I think TLs are inherently pretty well braced, but you could also make the walls very thick, which I think was the main factor in the Stance. I don't remember how thick Wolf made the walls, but it looked like at least 1.5" and maybe even 2.25".
Dan_____________________________
Tall Boys
NRNP Computer Sub
The Boxers
The Hurricanes
The Baronettes
Conneccentric
UX3
Originally posted by DanP View PostThat was Wolf's Stance that used the RS125, and hearing that speaker has also made me lust after an extremely dead box. I've heard the RS125 before and it has NEVER sounded better IMO. I think TLs are inherently pretty well braced, but you could also make the walls very thick, which I think was the main factor in the Stance. I don't remember how thick Wolf made the walls, but it looked like at least 1.5" and maybe even 2.25".
Dan
Originally posted by duanebro View PostJust wondering how much I can brace a TL. This will just be for a 6" woofer.
Dan
Also remember that the port was a dual-flared type with a large radius on the exit so there was no turbulence.
The sides are 1.5", the back was 1.25", and the top/bottom/front was 0.75". The sides were thick to facilitate the mass loading internally, and the back/sides/port/top are all tied in with a couple shim-braces and the 1.25" dowel across sides just below the middle.
I do think a thicker-walled TL ould do as you want, just use a core-box in your router and match the patter on both sides of the panel if you want to fill the panels. Don't pre-attach and use elbow grease and a drill like I did. ;)
Thanks for the compliments, fellas!
Some advice I've gotten is not to change the cross section of the line (i.e. no window brace. Dowels, axe handles, etc would work well since they aren't changing the line significantly.I was so much older then, I'm younger than that now.
Originally posted by fastbike1 View PostSome advice I've gotten is not to change the cross section of the line (i.e. no window brace. Dowels, axe handles, etc would work well since they aren't changing the line significantly.
One thing to be said for window braces is that they keep the cabinet square, particularly when the bottom is open. (I use the plinth to close my pipes.)
Bob
You got bad advice from someone that didn't know what they were talking about. Window braces work just fine as long as you don't get carried away with the size of their cross members and side members to the point that the cross-sectional area is severely restricted.
Paul
Thanks for the clarification. Not having any experience designing TLs, what's a ball park for severely restricted? 10% loss of section, 25%, ?
Originally posted by Paul K. View PostYou got bad advice from someone that didn't know what they were talking about. Window braces work just fine as long as you don't get carried away with the size of their cross members and side members to the point that the cross-sectional area is severely restricted.
PaulI was so much older then, I'm younger than that now.
I've never performed that specific calculation, but let's look at an example. Let's say the internal dimensions of the line's area are 9"W x 9"D. If I use a window pane brace where all of of its members are 3/4" wide, the area of the 4 windows will total to 45.6 in2, out of 81 in2, or 56% open (44% restricted, so to speak). I've modeled the effects of such a brace in a TL and they simply aren't visible in the modeling graphs. As the line's cross-sectional area becomes smaller, the widths of the brace's members would need to be reduced, and as the line's area becomes larger, you could, and would probably want to use brace members that are wider.
Paul
Originally posted by fastbike1 View PostThanks for the clarification. Not having any experience designing TLs, what's a ball park for severely restricted? 10% loss of section, 25%, ?
Thanks Paul, that was a great example.I was so much older then, I'm younger than that now.
You're quite welcome. How much a window pane brace would affect a TL's performance is determined both by how much the line's area is reduced and how thick the brace is. With window braces typically either 3/4" or 1" thick, their negative effects lie somewhere between zero and miniscule.
Paul
Originally posted by fastbike1 View PostThanks Paul, that was a great example.
