Pioneer SP-BS21-LR - measured/deconstructed/modded
  • Pioneer SP-BS21-LR - measured/deconstructed/modded
    CABINET:DRIVERS:LISTENING IMPRESSIONS:VALUE PROPOSTION:
    Bryan K.
    Midwest Audio Club
    Speedster | Sub Attachť | The Wildeman | Sean's NLA Towers | CO‹GAR, COUGAR II and CO‹GAR JR | Triton | Lithium | J-Boom | Trym MLTL | Docere MLTL
    Re: Pioneer SP-BS21-LR - measured/deconstructed/modded
    I'm very curious about those speakers. They seem like the steal of the year at $50!
    I wonder if they'll measure like these ones. http://www.stereophile.com/content/p...r-measurements
    Line Array: IDS-25 Clone, FE-83.
    2-2.5 Way:
    Zaph Audio's winning entry: ZA5+SB29. - Microliths: RS125+RS28. - Small Bangs: TB W4-1658SB+SEAS 27TBFC/G. - Monoliths: Peerless 830884+SEAS 27TBFC/G.
    3-3.5 Way:Miniliths: SEAS P21/CA21REX+Neo8 PDR+Neo3 PDR. - Megaliths: 2xDayton RS270+2xT-B W4-1337SB+SB29. - ZDT3.5 +: 2xDayton RS180+Dayton RS52+Vifa DQ25. Reflexos: OB 4xDayton RS150 + Neo3 PDR.
      I am no scientist when it comes to measuring and I have nothing close to an optimal space to do so, however, since this will be a comparison to the Speedsters, the measurements should yield something of value.
      Testing methodology:
      Speaker on edge of table 30” from floor. Ceiling height 10 feet and nearest side boundaries at least 6 feet away. I took two sets of measurements using a quick sweep in TrueRTA, measured with a Cross Spectrum calibrated ECM8000. Both measurements on axis, mic lined up in between tweeter and woofer – 20” away and then 10” away. I also measured port response with the mic right at the port exit.
      BS21 - 20"
      Speedster - 20"
      BS21 - 10"
      Speedster - 10"
      20" comparison - BS21(green) - Speedster(purple)
      10" comparison - BS21(yellow) - Speedster(gold)
      BS21 - port
      Speedster - port
      Port comparison - BS21(blue) - Speedster (green)
      Bryan K.
      Midwest Audio Club
        Bryan K.
        Midwest Audio Club
          Plastic frame for woofer removed. Note the singular baffle brace and the small amount of poly-fill.
          Top half of cabinet, looking thru tweeter cutout. Note the 1.5” I.D. x 2.5” port.
          Crossover – double-sided on a PCB – 6 elements – uses a NPE and a poly cap, an air core and a steel core inductor and two 5-watt resistors.
          Some physical measurements of the cutouts, etc. (in inches on the caliper readout)
          Woofer:
          Tweeter (recess):
          Tweeter (cutout):
          Baffle thickness – 0.59” which equates to 15mm MDF.
          BS21 in pieces:
          Bryan K.
          Midwest Audio Club
            So it looks like the MCM 55-3870 will fit right in there. What tweeter?
            What do you think of this one..http://www.parts-express.com/pe/show...number=264-804
              Whenever I measure speakers using RTA I get similar looking graphs to yours... it's interesting to see how your perceptions matched the measurements very closely.
              2-2.5 Way:
                I have to learn how to use TrueRTA better.....I don't do smoothing, gating, splicing, etc. And yes, I also noticed that the charts pretty much confirm my listening impressions. I was really happy to see that BTW, as I don't think I have very stellar ears for critical judgement.
                Bryan K.
                Midwest Audio Club
                  I took the following measurements of my pair of SP-BS21's using ARTA several months ago. The on axis wasn't very pretty but that 10K dip and spike smooths out off axis.
                  On axis:
                  Off axis, 30 degrees:
                    Stupid here. What I was reading with Audessey as a "bump" near 8Khz is really the dip at 9-10Khz. Duh, duh, duh, ah forget a plus in Audessey is ah minus in response, doh, doh, doh. The "BBC" dip looks like an artifact of the XO/driver spacing. It doesn't show the tweeter diffraction I would really have expected. Give me some T/S numbers and I'll sim the speaker/enclosures and if we get some measurements on the XO, we'll get seriously dangerous. A $25 speaker really worth spending time, effort and money on! Someone needs to call Zaph and warn him! I've simmed three possible MCM woofers in +/- 7L, and I'm not whelmed yet. Zaph's ZA14-8 woofer could be good medicine. It's about 139mm in outside diameter...decent numbers. I'll play with it.
                      very nice... I haven't had time to play with mine yet :(
                        I have them. Let me know how they sim. The ZA14 might drop right in that cutout without any modification. For the 4" drivers I want to test, I'm going to have to cut trim rings. I don't know why I get myself into goofy projects like this. Simple stuff turns into a nightmare pretty quickly. :rolleyes:
                        Bryan K.
                        Midwest Audio Club
                          the ND-105-4 might drop on to that 5.25" adapter plate
                            Yup....I thought about that too. I also happen to have several ND105-8's which will work perfectly. ;)
                            Keep the ideas rolling
                            Bryan K.
                            Midwest Audio Club
                              Two caps, two Inductors, and a internal brace. These are way overbuilt for "best buy" level audiphiles,
