For all you who know capacitors. Is this true...
  • For all you who know capacitors. Is this true...
    If you connect 2 like capacitors in series to a voltage, will the voltage will be divided between the 2?
    Let's say you're power source is 100volts. Does each cap get 50 volts?
    Re: For all you who know capacitors. Is this true...
    Short answer Yes...
    This may help ( see Kirschoff's Voltage Law )
    http://www.electronics-tutorials.ws/capacitor/cap_7.html
      Originally posted by Sydney View Post
      Short answer Yes...
      Thanks for that link. I'll actually read that from the very beginning page once i finish what I'm reading now. I'm reading a very informative paper on crossover design. Very helpful. I won't continue on into the paper if I bump into something that throws me off. I was in aware that this happened in capacitors. I would think that they would both just get equal voltages but I guess since they are in series it changes things a bit.
        Consider Voltage analogous to Pressure.
        Resistance in a mechanical pipe causes pressure drop.
        Assuming the devices are identical ( caps in this case ) the drop across each is equal.
        Kirchhoff's laws can be related to conservation of energy
          If they're truly IDENTICAL, then the voltage is split between them. For DC, you'd place some very high value resistors of equal value across the caps, so that leakage differences are minimized.
          Caps of equal value in series present a cap of half the value of one of them, but twice the voltage rating.
          Example: a pair of 2uF 50V caps in series will result in 1uF 100V. In parallel, 4uF and 50V rating.
            If you're talking DC voltage, then no. Capacitor resistance isn't defined or specified except in min terms. For dc voltage, you'd nwant to shunt each cap with a large resistor to set the dc leakage so they balance.
            Free & Free-form simulator/designer for Passive Crossovers
            SynergyCalc 5: design spreadsheet for Wooden horns and DIY Synergy Waveguides
            Super easy and cheap to make high performance sound diffusers
              Ah, so backwards from calculating resistors?
                I'm speaking in terms of a crossover. Which would be AC voltage correct?
                  Correct
                  "When capacitors are connected in series, the total capacitance is less than any one of the series capacitors' individual capacitances. If two or more capacitors are connected in series, the overall effect is that of a single (equivalent) capacitor having the sum total of the plate spacings of the individual capacitors. As we've just seen, an increase in plate spacing, with all other factors unchanged, results in decreased capacitance. "
                  From
                  http://www.allaboutcircuits.com/vol_1/chpt_13/4.html
                  • Capacitances diminish in series.
                  • Capacitances add in parallel.
                    Correct
                    From
                    The value is the inverse of the sum of the inverse of each cap.
                    A series connected set of 1uf, 2uf, and 4uf would be 1/(1+.5+.25) = .57uF
                      Yes. They are calculated the opposite of a resistor or inductor.
                        +1
