A couple questions on a new cabinet build.
  • A couple questions on a new cabinet build.
    Alright, so I've decided to build some cabinets with a design very similar to the dayton audio .50ft^3 cabinets. I want to build them out of 3/4" birch plywood. First off, I want to make the back wall of the speakers removable and i want to make a method of clipping the crossovers onto it since they are already built. Can anybody help me figure that out? And also, I will be lock mitering each piece so that they fit together seamlessly and dont show the plywood edges so that i can just put a nice stain on the plywood itself. The problem is that i want to make the front baffle a nice ebony stain and the rest of the cabinet a dark walnut stain, can anybody think of an easy way to do this? I can go with one stain for the whole thing if it is too complicated. Any input would be greatly appreciated.
    Re: A couple questions on a new cabinet build.
    My suggestion would be to make the front baffle overlap the sides, and do a roundover on it, this way you can stain it seperately. As far as the rear baffle, use weather a 1X2 or something to that effect inside that the baffle can screw into, and use t-fasteners. This way you can use a machine screw that will thread into the T-fasteners to hold the baffle tight, and weatherstripping will seal it.
    HAGD,
    Marc
    Even though I try to tell everyone upfront, understand that I am still a Newb. I wish the status of Seasoned Veteran/Senior Member, etc. was earned with time not posts...
    TMWW thread
    Maurbacs DCR Tower
      That's a good idea. I'm either going to do that or all ebony. Do you have any method of clipping the crossover plate to that rear baffle, so that it could be removed at any time for repair?
        'Y sertainly! Home Despot or Lowe's or a hardware store has nylon spacers in different ID's and lengths. Pick eight that will take round headed sheet metal screws of your choice, put quick connects on the inside speaker leads, attach XO board to rear baffle. Bingo! FWIW, I'd use some itchy fiberglass insulation over the XO board, just in case a resistor gets a little on the warm side, or mount it component side "down", so that isn't an issue.
          How about mounting the crossover to the back of the cabinet, and make a small enclosure that you can cover it with. Easier access for tweaking (and showing off). Plus, you can keep things away from the driver motors.
          For the birch plywood, don't use it unless it's something like Baltic Birch ply. Typical stuff from Lowes is filled with voids and doesn't make for a very nice enclosure material. If you have the good stuff, it's GREAT stuff, and will make for a very rigid enclosure. Consider cutting the panels with 45 degree cuts all around, so that only the outside surface shows. You could get all the pieces test fit perfectly, and then finish them separately, doing the baffle in a different dye from the sides, and then putting them together afterward. A little touch up and final seal and you'd be done. Mount that crossover on the back and cover it with a nice wood cover made from 1/4" ply that pops off with a couple screws.
            I've had very good success attaching crossover assemblies to the insides of speaker walls using industrial strength Velcro, making them very easy to remove. Depending on the size of their base boards, a 1" long piece of Velcro in each corner is usually enough.
            Paul
              I think im going to make an extra rear baffle for each speaker in case i want to make different crossovers. And the birch ply at my local lowes seems pretty nice. I used it to build a desk with very good results. Do you know of a common place to find baltic birch?
                Check a lumber yard or local cabinet shop. They might be able to lead you to the right place. There was recently a thread on MDF vs BB, and what most people ran into was that the Birch plywood available at Lowes or HD is just one layer of BB, then usually multiple layers of a lesser wood. The problem is that a lot of those layers have voids in them, and not only can these voids appear at the edges of your cuts, creating bad edges, but also they can cause some cabinet resonances.
                HAGD,
                Marc
                TMWW thread
                Maurbacs DCR Tower
                  Genuine Baltic Birch is a specific type of plywood, using specific woodb species.
                  Birch veneered plywood is neither, including the veneer.
                    Are there any alternatives to MDF and genuine BB? I hate MDF and BB seems a little pricey.
                      Marine grade plywood is better than the typical construction grade, but would need to be veneered when you're finished building the cabinet.
                      You could probably get all the BB you need for your project for about $50. Yeah, it's pricier than MDF, but it still shouldn't break your bank. I can't imagine you not being able to get all your panels from a single 5x5 sheet.
                        Look carefully at the layers of the Lowes birch faced ply. The half inch thick stuff will have like 3 layers of soft wood, then a very thin veneer face.
                        Even their regular A-B grade 1/2 inch ply has 5 or 6 layers of pine.
                        I've used the funky birch faced ply in the past, but I always tell myself "never again" - "just postpone the project and get some decent stuff"
                        Tangband W6-sub
                          $50 isnt too bad, I just need start looking around i guess.
                            You're right. I was looking at that wood and it seemed to have three layers of the crappy launa wood. I'm think about either going with the BB, or the PE cabinets themselves since they seem pretty nice. I tell myself "never again" for mdf, i hate that stuff.
                              I use MDF, but the dust! It's so fine, you need a particulate respirator. White dust masks are NOT adequate. I found a local lumberyard that always has the same color/consistency of MDF. I've worked with the big-box store stuff and there is a difference; and they never seem to have the same MDF that I bought the last time. Color and consistency are always different. But a good quality plywood is so much easier on your person and tools. The PE cabinets, while MDF, are very nice with 1" thick front baffles. We used to sell $5000-a-pair speakers that didn't have as nice a cabinet as what PE is offering. While I question myself about using PE cabinets and how much "DIY" there is to it, I think it's a terrific alternative for those that don't have a lot of confidence with their woodworking skills, or don't have the tools and/or space to make all that dust. I have the tools and space and still like to use the PE boxes.
                              John A.
                              "Children play with b-a-l-l-s and sticks, men race, and real men race motorcycles"-John Surtees
                              Yamaha KX-390 HX-Pro
                              Pioneer TX-9500 II
                              Yamaha YP-211 w/Grado GF3E+
                              Statement Monitors
