Guitar subwoofers
  • Guitar subwoofers
    To me, make zero sense. Even if it's a heavy band tuning down to A. That's only around 55Hz. Let's just say you were chugga chugging and electric guitar in drop A. Why a sub? A delta 12 would
    Cover that range just fine. Not to mention standard or drop D tuning. Seems completely unnecessary. Any thoughts?
    Re: Guitar subwoofers
    It's unnecessary
      I don't really see a need for it, either -- although, I've never tried it.
      Playing an electric guitar through a distorted amplifier (esp. modern amps and playing styles) creates more low frequency content below the fundamental than you might expect. For example, palm-muted chugga-chugging through a high-gain amp creates quite a lot of sub-fundamental content.
        I was thinking of doing something similar with my bass cab and a couple 8 inchers on top. I wouldn't exactly call it a sub. More like a woofer and mids.
          My thought when I saw the post was "absurd, why would anyone want to build that?" Every bit as stupid as putting a tweeter on a guitar amp for the same reason. An electric gtr is a very limited range instrument.
          Eric
            One 15 and a small mid could get loud in a fairly small box.
              I think the 15 would be overkill. I would much rather have 2x10s. The mid wouldn't be a bad idea to play with.
              Eric
                Where are these "subs" crossing and where have you heard about these?
                  I agree but you could put it in a small sealed box use all the low end boost you want and still get really loud assuming you have the power. So you could have a small loud 15 with mid or haul a 4x12 (for metal heads in crappy bars without good sound setups). Otherwise I agree 2x10 is plenty for most and 2x12 should be plenty for almost anyone.
                    One other thing. In my situation I play bass and guitar and something like this could pull double duty. Also full range cabs work great with amp modelers.
                      Here's the only one I know of:
                      http://www.rivera.com/products/powsub/sub2.php
                        Sounds like the xo in the midrange to reduce distortion caused by excursion. That thing weighs 120 pounds :eek: Thats as much as my mesa boogie 6x10 bass cab! My brother likes to play guitar through my mesa. Loud and clean lows in one 120lb box. I bet it gets louder than that sub.
                            Most ( conventional ) guitar players are not concerned with LFE as much as tone and SPL.
                            Of course musicians often do unconventional things to obtain a sound; Jeff Beck ( at one time ) would lay a cab on it's back - cones skyward.
                            Or use an FX ( like a harmonic generator/synth ); I saw CGT perform with no stage amps/speakers whatsoever - Acoustic Guitars went into pedal board and they monitored via IEM.
                            Lexicon Harmonizers were used to make a standard Acoustic Guitar drop octaves for the bass line.
                            Physics mandates a subwoofer be large If it also is to produce high output per watt in. There is usually a lot less air volume to push in a home than a live gig, so the Inverse Square Law becomes more important.
                            Not to mention swamping a stage with LF, when other performers are involved.
                              Harmonics, harmonics, harmonics.....
                              You put in the right frets and you can watch a speaker move by bending the string a bit....
