Why don't I ever see these....?
  • Why don't I ever see these....?
    Why don't I ever see these discussed as subwoofer amps?
    http://www.parts-express.com/pe/show...number=245-500
    For $299 you get 1,100 Watts in 4 Ohm Bridged mode, with an adjustable 4th order L-R active filter, peak llimiters, and you could use balanced inputs and Speakon connectors if you want. Seems like it could be a killer sub amp, or are people just afraid of the fans?
    Re: Why don't I ever see these....?
    There are a few people that use these Crowns, and generally seem not to be taken seriously for doing so.
      I have one of these, I think lots of people do.
      http://www.parts-express.com/pe/show...number=248-748
      I've had it awhile but I think I need that Art Cleanbox or something, it doesn't put out much power. I haven't bothered to actually see what the problem is yet.
      It has serious fan noise issues.
      Don't even try
      to sort out the lies
      it's worse to try to understand.
        I think a lot of people think pro sound gear is not hi-fi. I find this funny considering pro gear is used to make recordings. The other problem IMO is that the drivecore are ugly. Also you have a pm.
          Jeff, if you go to hometheatershack where guys _really_ build subs you will see tons of builds using pro amps.
          I use an old Crown PS-400 for my sub.
          And the drivecore amps are very well regarded.
          The only downside I see in pro amps are the fans. But the newer class-D amps are very efficient.
          Salem
            Originally posted by eyekode View Post
            Jeff, if you go to hometheatershack where guys _really_ build subs you will see tons of see lots of builds using pro amps.
            Yeah those guys over there build some real monsters. LMS Ultra 18's and big Crown amps flying all over that forum.
            Incidentally, this may be a strong contender for my new amp down the road. Thinking of upgrading to one of the new Stereo Integrity 18 D2's, and I'm going to need more juice...
            RYAN N.
            "Why do you have the stereo on while you're watching TV?" - "....Cause I like to party."
            RSS390HF Build - http://techtalk.parts-express.com/sh...d.php?t=224998
            AviaTrix Build - http://techtalk.parts-express.com/sh...d.php?t=230372
            Wolf's PC Speakers Build - http://techtalk.parts-express.com/sh...84#post1838384
            Overnight Sensations MT Build - http://techtalk.parts-express.com/sh...ation-MT-build
              I want one. When (if) my Nr709 sells, and I pay some bills I'll pick one up.
              रेतुर्न तो थे स्रोत
              return to the source
              leviathan system thread
              deadhorse thread
              shockwave build thread
              instagram :: greywarden_13
                I use pro amps for even small sealed subs. It's nice having 3500 watts on tap.... though I blow the breaker if I use it all :D
                  Grey, you mind PM'ing or emailing me details about your 709? I need something to replace my 608 that is 4 ohm stable!
                  RYAN N.
                    There has actually been quite a bit of discussion about the Drivecore series as sub amps and main amps. The XLS1500 and above have a significantly better S/N ratio than the XLS1000, and are often recommended if the application is a mains amp. The XLS 1000 makes a great amp for a pair of subs.
                    User reports say that the fans either never come on or are inaudible if they run.
                      XLS1000 here for sub duties and it rocks for that purpose.
                      I don't like it as a full range amp, but I wish I got to hear the 1500 due to the improved SNR that fastbike mentioned.
                        Jeff, the fans are simply a non-issue in this particular amp.
                        As for why the XLS drivecores is not used as a sub amp... because it's just too good as a stereo amp :P
                        But seriously there's a lot of people using them. You've just been oblivious.
                        :blues: Flat frequency response, a smooth sound power response free of resonance, careful driver-integration, and high dynamic range both upward and downward :blues:
                          Ive got the xls2000 and you need the cleanbox pro to convert rca to xlr. It does it good superbly and i have no complaints about it. There is no fan noise and the settings are easy to configure. Not only it drive sub, its a 2 channel stereo amp which you can drive your speakers with it.
                            I have a 1500, Jeff- and I like it alot! I use it for mains. =-)
                            I plan on another one down the road for Charybdis with the Dayton Proto-LVS15.
                            I might even part-out Marianas if that does as well for me!
                              I use an EP4000 for my pair. With a 5 minute fan swap and a couple 1/4"-RCA adapters its been working fine for almost three years. +1 on the Home Theater Shack forums, those guys LOVE pro amps for sub duties.
                              Your results may vary.
