I am building a T Line Sub for my Home Theater. I am using an 8 inch sub I had laying around. Can anyone give me some rules of thumb on the size of the cabinet? I wan't to build it so it is standing up against the wall, sub at the top of the face plate. Any sugestions on the size of the channels, port, etc! I have purchased a 4 x 8 sheet of MDF to construct the cabinet out of, so should have plenty of material. I have watch some youtube video's on the constructing these and have not noticed anyone using polyfill or insulation, etc, is that right or should I use some and where? Thanks for all your help, Be Blessed, Jim
Building a T Line Sub
Re: Building a T Line Sub
Can't really answer your questions specifically without knowing what the woofer's T/S values are. Also useful are your approximate size and shape desires as well as how low you want F3 to be.
Paul
Originally posted by BrunsDad5 View PostI am building a T Line Sub for my Home Theater. I am using an 8 inch sub I had laying around. Can anyone give me some rules of thumb on the size of the cabinet? I wan't to build it so it is standing up against the wall, sub at the top of the face plate. Any sugestions on the size of the channels, port, etc! I have purchased a 4 x 8 sheet of MDF to construct the cabinet out of, so should have plenty of material. I have watch some youtube video's on the constructing these and have not noticed anyone using polyfill or insulation, etc, is that right or should I use some and where? Thanks for all your help, Be Blessed, Jim
Originally posted by isaeagle4031 View PostYou aren't going to fit a tline into that box space. It just isn't big enough.Don't even try
to sort out the lies
it's worse to try to understand.
Originally posted by BrunsDad5 View PostI am using an 8 inch sub I had laying around. Can anyone give me some rules of thumb on the size of the cabinet?
What Paul and isaeagle are getting at is that we use software to simulate our enclosures instead of using old, tired rules of thumb. That's why we need detailed t/s parameters, which you have not provided. You won't likely be able to get them from the manufacturer either but you can measure them yourself if you are so inclined.
Type: 8" bass reflex, tuned port enclosur e
Maximum Output: 101 dBDon't even try
To sum up what everyone has said, there simply is not enough information on the driver, particularly its T/S values, to model it in a TL, and trying to use Rules of Thumbs to do so will most likely be fraught with bad results.
Paul
First measure the T/L specs for the driver. I describe an easy / cheap way here http://zobsky.blogspot.com/2008/01/s...t-jig-for.html
Originally posted by Paul K. View PostTo sum up what everyone has said, there simply is not enough information on the driver, particularly its T/S values, to model it in a TL, and trying to use Rules of Thumbs to do so will most likely be fraught with bad results.
Paul
Originally posted by BrunsDad5 View PostOkay, I give! It is not in a box now, so I need to build something. How about a basic box style, any hints! Thanks, Jim
Amplifier: 100 watts continuous into 4 ohms
Auto Power On: 2 second ON delay, 15 minute OFF delay
Dynamic Headroom: 1 dB (125 watts into 4 ohms)
Audio/Video Switch: +3 dB over entire frequency range
Low Pass Crossover: Continuously variable from 40-120 Hz,
24 dB/octave slope above 120 Hz.
High Pass Crossover: Main speakers: line level outputs with switchable high pass between 40 and 80 Hz, 6 dB/octave slope above
120 Hz. Speaker level outputs with fixed high pass at 100 Hz,
6 dB/octave slope.
Phase: Switchable 0-180 degrees
Inputs/Outputs: Line level RCA phono jacks. Dedicated LFE
channel input. High level speaker terminals.
Drive Component: K-1048-K 8" (20.32 cm) driver Fiber-composite cone
Weight: 39 lbs. (17.7 kg)
Height: 14.75" (37.47 cm)
Width: 13.5" (34.3 cm)
Depth: 13.5" (34.3 cm)
Cabinet: Medium density fiber board construction (MDF)
Finish: Matte finish black vinyl
Voltage: 110/120 VAC 60 Hz – Dual Voltage Export Version
230/120 VAC 50/60 Hz
But note that if you don't have the original amp (which might have built in digital signal processing) it still might not amount to the original Klipsh product.Don't even try
