Is 16 ga adequate for an 80 foot speaker run?
  • Is 16 ga adequate for an 80 foot speaker run?
    250 watts, speaker is high passed at 80-100 hz, so it's not producing any deep bass
    Thanks!
    Form does not follow function
    Form is simultaneous to function
    Re: Is 16 ga adequate for an 80 foot speaker run?
    I won't directly answer you, I may be hesitant to do such but there are gauge/length calculators out there on the web to answer you.
      Thanks Rotech
      I've seen a few charts that suggest I should be using 14 ga...
      But what I can't find is any info on "if the speaker is high passed"... doesn't the high pass mean I can get away with a thinner gauge? Perhaps not...
        Here is a chart of wire vs. length by Linkwitz...
        http://www.linkwitzlab.com/orion-faq.htm#Q10
        It's in context of a best-case scenario (no passive crossover), but it has some useful information to get you started.
        Bill Schneider
        www.afterness.com/audio
          No it's irrelevant, the wire gauge required is based on the total distance being covered and the power level being delivered.
          Paul O
            This is better, as it considers current as well:
            http://www.bcae1.com/images/swfs/spe...rassistant.swf
            Not. There are two considerations, the dB insertion loss and the cable current capacity. With a high passed signal power demand, and therefore current draw, is lessened, but that has no effect on the insertion loss. Where you can get away with using a lighter gauge, a much lighter gauge at that, is with the wiring of mids and tweeters inside the cab, where even the smallest wire doesn't present an insertion loss issue and you can take advantage of the reduced power/current requirement.
            www.billfitzmaurice.com
              As Paul O said, high passing at 80-100 Hz is irrelevant. 250 watts of power at 40 Hz vs 250 watts of power at 1 kHz, is still 250 watts. Of course, this assumes that you're truly pushing 250 watts above your high-pass frequency.
              At an 80 foot run x 2 conductors, you're looking at approx 1 ohm with copper wire. With an 8 ohm load, you're looking at dropping ~11% of your power in the wire and losing ~1dB of output. With a 4 ohm load, you're dropping ~ 20% of your power and ~2dB of output.
              EDIT: Oops, my calcs here are based on 18 ga wire.
                High passing at 80-100Hz may not be major, but it's certainly not irrelevant, as power density is reduced by 3dB for each octave increase in the high pass frequency. To oversimplify, what takes 250w from 40Hz requires only 125w from 80Hz. You don't have to go very high with the crossover frequency before power loss is a moot point compared to insertion loss in dB.
                  80 ft of 16 gauge would have about 0.32 ohm DCR for each single wire.
                  http://en.wikipedia.org/wiki/American_wire_gauge
                  Not counting the inductance and other possible effects, you can simulate the effect of 80 ft 16 gauge wire( actually a pair of wires) by using a very short run of speaker wire in series with 0.32 ohm resistor for each wire. If the speaker sounds good to you then it should be all right.
                    Hence the reason I said "this assumes that you're truly pushing 250 watts above your high-pass frequency."
                      Thanks guys. I went ahead and got a 14 gauge wire instead.
                        I can understand wanting to save some money for a long run like that. Generally, I will go over kill. Higher gauge wire has less resistance. While it might not be obvious in a AB comparison, it is measurable.
                        For me, pure copper cable, soldered connections, good quality connectors.
                        I don't expect anyone to believe me, but it could have sworn I've heard a difference going between thin cable and thick cable. At any rate, the price difference isn't much, so I'll just go with what has the least amount of resistance.
                          Originally posted by generic View Post
                          ... Generally, I will go over kill. Higher gauge wire has less resistance. ...
                          I'm the same way... I refuse to use 14 AWG in house wiring and will always use 12 AWG.
                            The biggest effect is that the increased series resistance of a long high gauge run will add fluctuations to the frequency response of the speaker which are dependent upon the impedance profile of the speaker. This can add a slight midrange hump where the impedance peak is, and also effect the bass tuning.
                              Unless you're seriously under-gauged there won't be enough resistance to make that much difference; you can find an ohm or more difference in the output impedance of amps, which would have even more effect.
                              I try to avoid more than a 50 foot run, not because of resistance issues, but capacitance and inductance. In pro-sound typically we put the amps as close as possible to the speakers, and let the long cables in the system be the line level sends, as those create fewer issues than long speaker cables. And you can use 22ga.
