So what are some of the "Little Things" you never think of when you're ordering drivers that you're inevitably going to have to run to the hardware store and hope to find?
All The Little Things...
रेतुर्न तो थे स्रोत
return to the source
leviathan system thread
deadhorse thread
shockwave build thread
instagram :: greywarden_13
in war, victory . . . in peace, vigilance . . . in death, sacrifice.Tags: None
Re: All The Little Things...
Radio Shack emergency runs:
Gold plated banana connector terminal cups
Euro-style terminal strips
Internal 16 or 18 gauge wiring
Tangband W6-sub
Fastons (Like 50 said, good luck getting the perfect sizes too).
Gasket tape. I use the stuff Meniscus sells because it's only 1/16" thick and it compresses enough so that you don't have to factor it into your driver recess measurements.
The correct mounting bolts. You kinda have to plan this in advance. Are you using wood screws or machine bolts?? Again I think MENISCUS has a nice selection of these.
Usually when I order drivers it means that I have a build in mind, so I also might buy Terminal Cups or Binding Posts. I'll look at the port tubes just in case there's the perfect one for my build. That never happens though and I usually end up using Schedule-40 PVC. I like Dayton Sonic Barrier and I never seem to have enough of it laying around, so that might be another cart entry when I'm purchasing drivers. Before you know it, you're easily spending enough $$$ to get free shipping from PE....YAY!! :applause:Bryan K.
Midwest Audio Club
Speedster | Sub Attaché | The Wildeman | Sean's NLA Towers | COÜGAR, COUGAR II and COÜGAR JR | Triton | Lithium | J-Boom | Trym MLTL | Docere MLTL
Don,
That reminds me - Steve @ Apex has 4 Section Euro terminals (large ones) - 3 for a buck. These have no trouble at all with 16AWG wire and can do larger wire as well. I find these easier to work with than the small ones from the shack.
You have to scroll pretty far down the page: http://apexjr.com/new.htmBryan K.
Midwest Audio Club
Ditto for me for items 2 and 3. In fact I just stopped at Radio Shack yesterday to pick up a couple of the Euro-style terminal strips while making a run to Home Depot.
Paul
Don't forget a pair of these bad boys: http://www.amazon.com/dp/B000J36XR2/
Only between $13K and $14K on amazon!
Nah but seriously, the propper fastener hardware, solder, hook up wire, etc...RYAN N.
"Why do you have the stereo on while you're watching TV?" - "....Cause I like to party."
RSS390HF Build - http://techtalk.parts-express.com/sh...d.php?t=224998
AviaTrix Build - http://techtalk.parts-express.com/sh...d.php?t=230372
Wolf's PC Speakers Build - http://techtalk.parts-express.com/sh...84#post1838384
Overnight Sensations MT Build - http://techtalk.parts-express.com/sh...ation-MT-build
Originally posted by scardeal View PostCrimp on spade connectors for internal wiring
IIRC they were clearing out packs with 30 or so of each size (190 total) for around $10 a box. Perhaps they still are.
They're nicely-built terminals. Thin enough to be easy to crimp with a hand-crimper, thick enough to hold on once crimped. Only real complaint is that the plastic blister is secured with metal inserts, so you need a screwdriver to open it.--
"Based on my library and laboratory research, I have concluded, as have others, that the best measures of speaker quality are frequency response and dispersion pattern. I have not found any credible research showing that most of the differences we hear among loudspeakers cannot be explained by examining these two variables." -Alvin Foster, 22 BAS Speaker 2 (May, 1999)
Make sure I have enough solder. Sandpaper in the various grits, and more hot glue sticks! Before I start cutting, I get some replacement cartridges for my particulate respirator. Cheap and easy to replace; simple thing for protecting your lungs, especially cutting/routing MDF. Keeping the correct lube for my router bits that have bearings. Enough of that cleaning sauce for the bits and saw blades. I've amassed a large selection of different screws, both machine thread and coarse thread. I replenish my stock of crimp-terminals and make sure I have enough shrink-tubing in the appropriate sizes. I use the shrink-tube over the crimp connectors and any directly-soldered joints...I also use it for polarity ID or color-coding so I know which wires go to which driver(s). Do I have enough wood glue and epoxy? Are my tools in good working order? Anything questionable or broken? Recheck my order, are there any items that I could stock up on? Caps, coils, resistors, terminal cups/binding posts? How about stuffing or egg-crate foam, maybe some grill cloth or those liitle magnets you can attach a grill with. Finishing supplies such as tung oil, clean wiping cloths, gel stain and gel poly top-coats. Oh, a good supply of utility knife/razor blades and/or Xacto knife blades. Nothing can ruin a veneer trim faster than a dull razor-knife blade.
John A."Children play with b-a-l-l-s and sticks, men race, and real men race motorcycles"-John Surtees
Yamaha KX-390 HX-Pro
Pioneer TX-9500 II
Yamaha YP-211 w/Grado GF3E+
Statement Monitors
Originally posted by johnastockman View Post.... Keeping the correct lube for my router bits that have bearings. Enough of that cleaning sauce for the bits and saw blades.
रेतुर्न तो थे स्रोत
deadhorse thread
"All The Little Things..." is something my wife tells me when I start to open my mouth about anything speaker related.
But, for some reason a project is not complete unless it involves a few unplanned trips to Lowe's.If we all reacted the same way, we'd be predictable, and there's always more than one way to view a situation.
What's true for the group is also true for the individual. It's simple: Overspecialize, and you breed in weakness.
It's slow death.
//Burn n' Die//Dream Weaver//Maximus//ABC Bookshelf Speakers//Dayton Twin Towers
