Originally posted by peepaj
View Post
Dayton Audio DC28F-8 cutout diameter wrong on PE?
Re: Dayton Audio DC28F-8 cutout diameter wrong on PE?
I use this.
http://www.harborfreight.com/1-2-hal...der-92158.html
I have a router so I think I'm just going to notch that area out once I figure out the measurement and placement. I been up all day and I'm burnt out. See you all tomorrow.
I've used a mini hack saw in the past for notch work. It's flimsy but it will work. I had problems with bending the blades so you have to have a light touch. Just a cheap idea.
http://www.homedepot.com/p/Stanley-1...-809/100026795
Originally posted by xsundown View PostThanks for the replies. I have nothing to notch it out with. I'm thinking about using a drill and drill bit to notch it out a little.
For a one time notch, a drill and a small drill bit will do the trick for sure. Good luck.
I'm sure all of us who use this marvelous little tweeter are running into the same problem. The magnet actually measures 2.75", but there is a larger ring next to the faceplate -- it actually is part of the faceplate. That ring requires that the mounting cutout (we used to call it a "hole";) be cut to 2.9." Following that, simply cut out a notch to accomodate the terminals, approximately 1/2" deep and 1.25" wide. You will need to bend the terminals in a little toward the magnet. This done, they fit like a glove.
GeeDeeEmm
Yup - you have to notch that out. There's several ways to go about it. I wouldn't advise to make the entire hole larger because you won't have enough material left for your screw holes. Like Marc said - cut a notch....sort of like this, but only one in your case.
I just end up cutting a notch out for the terminals.
There is no way in hell I can cut it out to 2.73 (3/4). There are speaker terminals that they must not be accounting for. I just did it with 3 9/16 and the terminals fit through fine. I'm going to go 1/16th of an inch smaller to 3 1/2 just so the screw holes will have a bit more latch on. At 3 1/2 I may have my speaker terminals sit on the back edge of the MDF cut hole. Am I doing something wrong?Tags: None
