Re: How am I supposed to lay all this out?
xsundown, if you are still having a hard time with the layout, please give wolf your board size and let him lay it out for you. If not then you will have to do it like me and keep playing with the alignment until it fits. I wish I would have taken pics of mine for you before giving them away.
Wolf hope to see you at MWAF.
https://sites.google.com/site/undefi...-orientexpress
I used a different tweeter as the one he used is NLA. This of course made for crossover changes, if you look at his crossover point of 3100 to 3200 Hz. I have a crossover point of 2000 to 2100 Hz.
The sims below are done using in box measurements, so things below 300hz or so is my garage talking back to me or you could say reflections.
Originally posted by Mark65 View PostOther than that, you have it just right.
Originally posted by Mark65 View PostNo, you have an inductor where a capacitor should be. I'm guessing that's your .22mH coil, that instead needs to be a .22 uF cap. Other than that, you have it just right.
Originally posted by turn2 View PostPretty sure the upper left coil should be the .22uf cap, but I can't read any component values.Both white thingamuhbobbers are 4 ohm resistors, big coil in middle is 1.30mh, 10uf capacitor.
Originally posted by xsundown View PostI'm going to want to build my own. Everyone is saying it's not hard so I'll give it a shot.
First crossover I made was from a plan in I think Popular Science magazine.
I wound my own coils on an engine lathe.
I had never done anything like that before.
It worked.
This is for the woofer.
Sure. The lines are wires, the dots are connections. Where the lines cross with no dot means no connection. The sawtooths are resistors, the two parallel lines capacitors, and the Hostess Cupcake squiggles are coils. A hot glue gun is nice for gluing components down. The values on the diagram are also on the components. Don't lose the labels off the coils. Good luck.
I have a soldering iron, solder, and a long piece of 1/4 wood flooring I think. If not, tons of cardboard.
Originally posted by Soundslike View PostFor an understanding how this build got to where it is now, one must read at least five other strings pertaining to this same project. Here are a few I've come up with, not in any particular order:
http://techtalk.parts-express.com/sh...peaker-project
http://techtalk.parts-express.com/sh...45#post1915945
http://techtalk.parts-express.com/sh...h-1-difference
http://techtalk.parts-express.com/sh...the-AC25SG05-4
http://techtalk.parts-express.com/sh...-to-parts-list
I'll wait to see what you decide to do -- you've been offered a couple of different solutions. I'd take advantage of them first, because even if you manage to get your crossover assembled, you may very well be disappointed with the result.
Depth of the slot port including the front baffle. The box is 10"deep internal.
How are you making a 9.5" port fit that baffle?
Originally posted by isaeagle4031 View PostUnless I screwed up my math, that is an 86.5Hz tune. Why so high? 6.5 sq in of port is more greater than a pair of 2" ports. Personally, I would use a port of .5in h x 9.5 (panel would be 8.75") for a tune of 47.7 and .35 net cubes if staying with a slot port and those box dimensions. For a lower tune, a 2"id port, 9" long will get you 44Hz.
Originally posted by thekorvers View PostWhen using a slot port, it is better not to exceed a height to width ratio of 1:8. You may deviate from this a little bit, but the proposed ratio of 1:19 is too high.
