How am I supposed to lay all this out?
  • #31
    Re: How am I supposed to lay all this out?
    Just follow the diagram and do each piece one at a time all the way down the line. Baby steps. Before you know it, you'll be kicking yourself for not realizing how easy it is to do.
    • #32
      You'd be surprised how many of us will help. If I'm going to fiddle with parts on a cross-over board, I like to use Euro-terminal strips to tie the leads together. I get the longest length ones from www.Allelectronic.com I can and cut them up with a hacksaw. Save money... I use low melt hot glue to hold parts down in case I want to change things. The good foam double-stick tape works too. You can do zip-ties like Wolf.
      • #33
        Originally posted by thekorvers View Post
        From what build / forum thread is this?
        Peepaj did the design, and he is a member on this forum.
        xsundown- I told you I would do a layout for you, and I never got a response. Heck- I'll even lay it out on pegboard graphic for you.
        I just need to know which parts exactly that you purchased. Just post the hyphenated part numbers from the order, and I can go from there.
        I also think Ryan would do a fantastic job, and you have nothing to worry about.
        • #34
          Here. I will send you the money to cover the parts cost, then pick any one on this forum....ANYONE. send them your parts. If you don't get completed crossovers back keep my money.
          That's how much trust and faith I have in this community. It's probably the ONLY forum I feel that way about.
          • #35
            This will be the cabinet I'll be making.
            • #36
              Do you(or does anyone) have the files for the SF woofer being used? I have no doubt that peepaj has designed an excellent xo, but maybe the circuit could be simplified a bit...and I'd be willing to take a crack at it, if you'd like.
              You go your way, I'll go mine. I don't care if we get there on time.
              ~Pink Floyd
              • #37
                Unless I screwed up my math, that is an 86.5Hz tune. Why so high? 6.5 sq in of port is more greater than a pair of 2" ports. Personally, I would use a port of .5in h x 9.5 (panel would be 8.75") for a tune of 47.7 and .35 net cubes if staying with a slot port and those box dimensions. For a lower tune, a 2"id port, 9" long will get you 44Hz.
                • #38
                  When using a slot port, it is better not to exceed a height to width ratio of 1:8. You may deviate from this a little bit, but the proposed ratio of 1:19 is too high.
                  • #39
                    http://www.madisoundspeakerstore.com...1/2-wool-cone/ This?
                    • #40
                      For an understanding how this build got to where it is now, one must read at least five other strings pertaining to this same project. Here are a few I've come up with, not in any particular order:
                      http://techtalk.parts-express.com/sh...peaker-project
                      http://techtalk.parts-express.com/sh...45#post1915945
                      http://techtalk.parts-express.com/sh...h-1-difference
                      http://techtalk.parts-express.com/sh...the-AC25SG05-4
                      http://techtalk.parts-express.com/sh...-to-parts-list
                      I'll wait to see what you decide to do -- you've been offered a couple of different solutions. I'd take advantage of them first, because even if you manage to get your crossover assembled, you may very well be disappointed with the result.
                      Tritrix HT:http://techtalk.parts-express.com/sh...d.php?t=222519
                      Dayton 12" Subwoofer: http://techtalk.parts-express.com/sh...d.php?t=222930
                      Overnight Sensations: http://techtalk.parts-express.com/sh...d.php?t=223751
                      Cerberus sub: http://techtalk.parts-express.com/sh...hlight=cerebus
                      Duellatis: http://techtalk.parts-express.com/sh...d.php?t=224943
                      NTN's: http://techtalk.parts-express.com/sh...d.php?t=227902
                      • #41
                        In some cases, I will agree. Given the power level these are apt to see, the ratio will not cause any ill effects. I have built many slot ports pushing the ROT ratio and have had no ill effects.
                        • #42
                          How are you making a 9.5" port fit that baffle?
                          • #43
                            Depth of the slot port including the front baffle. The box is 10"deep internal.
                            • #44
                              I'm going to want to build my own. Everyone is saying it's not hard so I'll give it a shot.
                              • #45
                                I have a soldering iron, solder, and a long piece of 1/4 wood flooring I think. If not, tons of cardboard.
