Vifa NE149W
  • Vifa NE149W
ID:	1185245Click image for larger version
ID:	1185246Click image for larger version
ID:	1185247Click image for larger version
    Uber motoren Vifa midrange. Tested and re-tested it recently.
    http://www.diy-ny.com/
    Re: Vifa NE149W
ID:	1150212Click image for larger version
ID:	1150213Click image for larger version
Name:	dist 2.89v.jpg
    there's a slight bump in FR between 1khz and 2khz. It's accompanied by a small distortion bump. Omnimic also showed small amount of ringing in this area. Looks to me that mild LCR can be beneficial. Improved cone and lower 2nd order distortions would make this driver a Revelator killer. As is, it's just very good.
      Re: Vifa NE149W
ID:	1150215Click image for larger version
        Re: Vifa NE149W
        Looks good!
          Re: Vifa NE149W
          "Improved cone and lower 2nd order distortions would make this driver a Revelator killer. As is, it's just very good."
          That and a $40 price reduction.
            Re: Vifa NE149W
            The 2nd harmonic is below 1% over its entire range, the 3rd is around .1%, and the higher order stuff is almost non existent. the only thing it doesn't have compared to a Revelator is as smooth a response.
              Re: Vifa NE149W
              Pete's findings match Curt's. The Finalist's use the NE149 for a mid. IMHO, it's one of the best sounding mids I've heard, period. I quit "lusting" for a Revelator when I heard the NE149. :D
              Jim
                Re: Vifa NE149W
                How is the VIFA NE123W-04 compared to it's bigger brother?
                  Re: Vifa NE149W
                  Sorry for my ignorance but what's the difference between those 2 distortion graphs?
                    Re: Vifa NE149W
                    The first one is a 2.89V, the second at 1.7V.
                      Re: Vifa NE149W
                      Thanks for the tests, Roman. Looks like these will do well for what I'm planning down the road.
                      "I have not failed. I've just found 10,000 ways that won't work." Thomas A. Edison
                        Re: Vifa NE149W
                        I love the look of those , great to hear they perform as well as they look! +1 on the price reduction;)
                          Re: Vifa NE149W
                          Thanks Pete. I see the reference now.
                          Is the 1.7V equivalent to Zaph's tests? Cause that graph seems actually a little better than the Revelator 15W8530K00.
                          and the NE149 again.
                          Looks like it could be about the same level of driver for half the money.
                            Re: Vifa NE149W
                            [ATTACH=CONFIG]37624[/ATTACH]
                            [ATTACH=CONFIG]37625[/ATTACH]
                            Zaph tests at [email protected] for his distortion tests. So power level is purely a function of driver sensitivity.
                              Re: Vifa NE149W
                              you are very welcome AJ.
                              I think, if you cross round about 2k, that hump between 1k and 2k can be dealt very easily without additional components. If you want to cross a bit higher closer to 3k, may be an LCR will be easier solution. For some reason I am thinking you wanted to cross that mid high up.
                              On the low end, I wouldn't let it play much below 300hz. 2nd order is upping and it's audible.
