Midwest Audio Fest
See more
See less
Horizontal MTM/CC
  • Horizontal MTM/CC
    Just a quick question that I couldnt find in some searches. Im aware that some MTMs will and some wont work well horizontally ie CC. What factors come into place here? What does one look at to see if it will work well horizontally?
    Re: Horizontal MTM/CC
    The main factors are, how far to the side will the listeners be sitting, how close are the woofers spaced, and how low does the mid/tweet crossover take place? Off axis performance of MTMs is poor in comparison to 3-ways with vertically aligned mid/tweet. If the seated position isn't more than 15 degrees off axis, most MTMs will be alright, but outside that position, intelligibility will become an issue due to deep nulls in the lower treble, upper mids where the two woofers interfere.
      One of the salient issues is how low the tweeter is crossed to the woofers (Lower usually means better for a center channel). But regardless, I believe that any side MTM should reduce horizontal dispersion. For many rooms this may be less than ideal (e.g. if you have a wide room), whereas a minority with serious acoustical issues (e.g. a side wall entirely made of glass) might benefit from this.
        whoops. Looks like Pete beat me to it.
          Well, the majority of the time the listeners will be in 15 degrees. Pretty rare that someone would be outside that range. Im looking at a very small C2C. I will be using 2" drivers paired with a ND16 with a xover somewhere around 3-5khz (havent gotten that far). From what you are saying, this sounds as if it will work for my needs, right?
            Should be fine then. Keep in mind that a pair of 2" drivers won't be able to produce much in the way of SPL. You'll want to cross them over actively with your HT receiver as high as you can.
              2" drivers? Why bother with a tweeter?
              Twitter: @undefinition1
                Well, use 3 of them and cross the center driver at 1KHz. Problem solved.
