comments suggestions on this for a extended pickup sub
  • comments suggestions on this for a extended pickup sub
    One of my sons friends wants to put a sub in his dodge extended cab pickup. He's thinking about using 2 of these pioneer ts-w304r subs with this Hifonics Brutus amp. He would like to put them under or behind the rear seats He's also looking at this enclosure.
    I'm wondering if there are better options out there for somewhere around 300-400. I've been pretty happy with Dayton drivers and wonder about the TangbandWT-1427G 10". I think he's more concerned with deep bass than sound quality. His dad does woodworking so building a box would not be an issue.
    I'd appreciate any thought, suggestions or links to projects.
    Re: comments suggestions on this for a extended pickup sub
    Is the budget 300-400 total, with amp included inthat price? Either way, there are definitely better options than those pioneer subs. I personally know someone who has had two of those blow on far less than the rated power.
      He'd like to keep it to that price for amp and speakers if possible.
      Any suggestions? Does he even need two drivers for a pickup?
      Thanks
        If he has the money and is ready to pull the trigger, the Dayton Titanic MK3 is the deal of the day and PE right now for $99. At that price its hard to compete, and it is an infinitely better driver than those Pioneer subs.
        http://www.parts-express.com/dayton-...4-ohm--295-414
        It has almost 400% more xmax, and only about 35% less cone area, which equals MUCH greater output, with much much much higher quality and its going to go deeper.
        Another option is this
        http://www.parts-express.com/dayton-...oofer--295-185
        Three times the xmax as one of those Pioneer subs with same cone area, so it moves 3x more air, again a much much much better driver and will play much lower, performs well in 1 cu ft sealed in a car.
        Using just a single one of either of these drivers will perform better than 2 of those pioneers, using two of either of these drivers will compete with four or more of those pioneer subs. Leaving him plenty of room to play with his budget/enclosure size, etc. So two of them wouldn't be necessary, but if spl is what he want, two of them would blow his mind.
          If it were me, I would go with Dustin's suggestion There is not nearly enough volume for those drivers. Better would be to buy the box and rework the cutouts to a 10"
            That sounds like a great option.
            Do you have any recommendations for a good amp?
            Thanks for the help guys!!!
              There are a lot of good amps on the market. Something in the 500w range at 2ohm. Dont forget to add about a pound of fiber fill as well.
                Have a look at the Truck tuba:
                http://www.billfitzmaurice.com/AutoTruckTuba.html
                  Nice idea but that won't fit under the seat of any extended cab.
                    It's intended for placement behind the seats, not under them.
                      Bill... I tried to PM a question but you don't receive PMs here.
                      "We are just statistics, born to consume resources."
                      ~Horace~, 65-8 BC
                        I understand that Bill. I was pointing out Thst the OP is asking about an enclosure that fits under the seat of an extended cab. I may try your design for the experience factor for myself. What is the response range of it?
                          I don't receive PMs anywhere, including my own forum. If I answered any I'd have to answer them all, and at over a hundred a day that wouldn't leave me time to do anything else.
                          It's a 40Hz horn. Response will vary from vehicle to vehicle due to all having different cabin gain. No one's found them lacking yet.
                            I guess I'll have to ask here then. What driver options are available for your TruckTuba? Sorry for the derailment.:o
                            ~Horace~, 65-8 BC
