i'm having problems with my current sub i decide to get a new driver for the box and now i get lots of port noise, the box is .5 cu. ft. and the port is 2.5 diameter and 9 inches long also the driver is Peerless 830946 6-1/2" Paper Cone Woofer Speaker 4 Ohm, some help i reduce the size of the port and it helps to tune it lower and it has less output and help with the noise a little.
port noise
Re: port noise
If you reduce the diameter (area) of the port, which will tune the system lower in frequency, you'll also increase the port's air velocity which is counter-productive. If the driver you installed is not the one for which the box was designed, that's the real cause of you're problem.
Paul
Originally posted by Yombo210 View Posti'm having problems with my current sub i decide to get a new driver for the box and now i get lots of port noise, the box is .5 cu. ft. and the port is 2.5 diameter and 9 inches long also the driver is Peerless 830946 6-1/2" Paper Cone Woofer Speaker 4 Ohm, some help i reduce the size of the port and it helps to tune it lower and it has less output and help with the noise a little.
Re: port noise
The new driver probably has more excursion (Xmax) than the old one. Model it with WinISD ( www.linearteam.org ) and see what's up. Reducing the port diameter will increase the chuffing, not reduce it. It might help to "roundover" the opening on the baffle (or wherever it exits), if it isn't already. That driver just might not work well in that size box (that's very small for a sub).
