Im almost finished with my speaker cabinets and I will be getting ready to paint them soon. I'm reading that it is difficult to paint MDF especially the edges. Can someone help me with some known products and procedures for filling, sealing, and painting MDF cabinets please? I would love for them to be gloss white. Thanks Mike D.
Painting MDF
Re: Painting MDF
Originally posted by Mike47 View PostIm almost finished with my speaker cabinets and I will be getting ready to paint them soon. I'm reading that it is difficult to paint MDF especially the edges. Can someone help me with some known products and procedures for filling, sealing, and painting MDF cabinets please? I would love for them to be gloss white. Thanks Mike D.
t-shirt and repeat when dry. Usaully 2 coats are enough, then lightly sand before proceeding.
Next I coat the whole box with a inexpensive waterbase poly (Minwax Polycrylic). Let it dry
thoroughly 48hrs,sand lightly and finish with paint of your choice.
Re: Painting MDF
Best stuff I've tried yet is Zinsser BIN. Shellac based primer. Seal and prime in one step. Use some bondo or wood filler on your seams, make sure they are smooth or the seams will show through the paint."I just use off the shelf textbook filters designed for a resistor of 8 ohms with
Re: Painting MDF
I tried some spray BIN and some "automotive fast-build primer" and liked the car primer better. Seemed to be easier to sand between coats and dried quicker.
There's several things that work -- just make sure you give whatever approach you use time to dry completely before you try finishing the whole thing.
Re: Painting MDF
I use Minwax Wood Hardener on the board ends and seams. Then the auto high build primer mentioned above. I also use the hardener on the driver cutouts so the wood doesn't swell when I prime/paint it, which causes the driver flange to sometimes not be flush with the surface the way you intended.
Re: Painting MDF
Hello,
trying to keep the number of different products in my workshop down, I tried using ordinary wood-glue and found that this (one layer 50/50 water, two layers glue) worked just fine!
Regards//lassePerry Mason talking to his dentist:
Re: Painting MDF
I've had good luck using Polycrylic as a sealer coat, however the current build I'm working on, I'm testing a new method. I skinned the cab with 1/8" MDF so the exposed raw edges are only 1/8" wide. My thought is that it should be easier to hide them since they are much narrower, they will also soak up less poly since there's less surface area to deal with. And of course it also brings the wall thickness up to 7/8" which helps to deaden the cab. I'll post a thread with my results as soon as I get started with the finishing, I figure even if they do end up showing they're close enough to the corner that it won't be very noticeable.
Re: Painting MDF
For the least expensive primer, Shellac based Bin primer works really well.
http://www.amazon.com/Shellac-Primer.../dp/B00113UKQY
Let it dry 24 hours before sanding or it will build up in your sand paper. It will take several coat to seal up the edges. Don't use the spray kind it is extremely thin.
Another thing that works even better is coating the edges with body putty. Just a real thin layer will seal edges right up. It helps to have some body work experience. You have to move fast and mix small amounts.
The main thing to remember MDF does not like moisture so the least amount you add in your finish process the better off you will be. That's why I recommend the shellac base primer. It dries quick. Any product that soaks in is not good. It will cause expansion which will cause a better chance of ghosting on the seams when all that moisture disapates.
If you really want to hide the seams I have a method in my signature that works. It does take quite a bit of work and some experience. Otherwise enhance the seams because they will more then likely show up over time. Depending on the finish you apply you may not be all that concerned.
If you like to read here is a thread that that explains a lot.
http://techtalk.parts-express.com/sh...-finishing-MDF
Dave
Re: Painting MDF
Can I sand and repaint acrylic latex enamel if I mess it up the first time? I had to repaint a kitchen cabinet door one time and I had to completely strip the paint because it kept leaving bleed through places. I Don't remember what kind of paint that was.
Re: Painting MDF
Is it ok for a little bit of wood to show through the primer after sanding? Ive put on three separate coats of Zinnsers BIN primer sanding between each coat. Even after three coats I still get the wood showing through in some places after sanding. Not real bad, if fact I can still see the primer in the wood, but it is thin. Do I need to keep priming and sanding until no wood shows at all? Thanks Mike D.
