2.1 Minions III/Voxel System Build
  • 2.1 Minions III/Voxel System Build
    Just pulled the trigger on the parts for a Minions III/Voxel build after getting approval from my manager at work for them.
    In this case I will be going a slightly different route using the PE micro bookshelf cabinets for the Minions. They are only slightly larger then the cabinets Lee used and I think they might work well with my desk.
    I was able to pickup most all my tools from southern California so I am going to take a crack at making the voxel cabinet myself.
    Will post pics and build info as it develops.
    Kevin
    Shaken, not stirred...
    Classix II
    OS MTM's
    Digger 8 sub
    Overnight Sensations Center Channel
    Sprite Build
    Wolf's PC Speakers
    Minions III with Voxel Sub
    Re: 2.1 Minions III/Voxel System Build
    Well I got some of the build done finally. I posted some pics below.
    The veneer is Tiger Stripe Maple for the baffle and Mottled Makore for the body.
ID:	1155717Click image for larger version
ID:	1155718Click image for larger version
    I will try to finish them this coming weekend so I can start using them at my desk on Monday.
    edit: Got a lot done week before last with Leroy R. I put the cabinet together and Lee and I glued on a scrap piece of MDF and he showed me how to flush trim the baffle. Lee showed me how to measure and create driver wholes with a jasper jig and flush mount the woofer. Had some fun running a table router for the first time but it came out OK. The next weekend was veneering the box.
ID:	1158820Click image for larger version
    Kevin
    Classix II
    OS MTM's
    Digger 8 sub
    Sprite Build
    Wolf's PC Speakers
      More progress has been made.
ID:	1156875Click image for larger version
ID:	1156876Click image for larger version
      Today I was able to finish the sanding and get them into poly, installed the terminals, and driver. I hooked them up to my AVR and played some music from the radio and and they sounded very nice. Tomorrow I will hook them up at my desk and some nice sounding music.
      edit: Finished the voxel sub today. I had to repair some of the veneer as it sat for week while the cement cured and somehow ended up with some boo-boos. I used the same technique I was taught from our local woodcraft store and for the most part I think it turned out ok.
ID:	1158822Click image for larger version
      Classix II
      OS MTM's
      Digger 8 sub
      Sprite Build
      Wolf's PC Speakers
        For a little size comparison I have posted some pics of the Minion III's with my OS MT's.
ID:	1156878Click image for larger version
        They are about 1/3 the size of the OS MT's. So I think they should fir nicely on my desk at work.
        Classix II
        OS MTM's
        Digger 8 sub
        Sprite Build
        Wolf's PC Speakers
          Ironic - I have ordered the same cabinets and the same Tang Band speakers for my son, and will build them as soon as they arrive.
          Sausage With Meat Sause, Please
            Ahhhh you're basically leading the path I want to follow! I have plans for this as well but want to get my first build under my belt before I start considering something like this but I've been saving up a bunch of links for 2.1 amps, take a look in the Voxel thread where I pasted a load there, here's another potential that I found last night:
            http://www.sureelectronics.net/goods.php?id=2600
            When I'm done with my first build I'm going to try and catch up with you! I can't wait to see what you think about the MIII/V combo :D
              I am not sure you would need 100 watts per channel to power the minions. We used a Lepai 2020 for our speaker comparison earlier this month and they rocked with just that.
              This little amp has been on ebay for awhile. the only PS I have found that should work is here: http://www.ebay.com/itm/221218791728...84.m1438.l2649
              here is another possibility: http://hifimediy.com/index.php?route...&product_id=64
              Once again I think it would be overkill but it may not reach the power rating anyway.
              I was going to use the Lepai 2.1 amp to start with since I have one already. And I will upgrade some time later.
              Kevin
              Classix II
              OS MTM's
              Digger 8 sub
              Sprite Build
              Wolf's PC Speakers
                Yep true, originally I was thinking about a 2.1 system with OS TM's or similar hence the extra power.
                Oh and that's one of the amps I posted in the official Voxel thread, I found the PSU, here is what I posted:
                FYI, 'Yuan-Jing' just emailed me this which they just got in and is a suitable PSU for their 2.1 amp:
                http://www.yuan-jing.com/ac-dc-adapt...ly-smps-24v-5a
                Problem is shipping from their site with the complete 2.1 amp is $66 on top of everything else, I believe I found the PSU from another source where shipping shouldn't be as expensive and then you can get the complete amp from AliExpress where shipping is free:
                http://www.amazon.com/Genuine-AD1202.../dp/B00D3B293Y
                http://www.ebay.com/itm/New-Genuine-...item3381aae130
                There may be more. I'm thinking about taking a shot but switching the OS TM's for 'The Minions II' I've just spotted over on another thread, trying to keep costs down for a 2.1 system!
                Though it appears the Amazon link is gone.
                  The enclosures for the IIIs you listened to here were 4.25" internal cube so the internal volume of those PE cabinets is less than .3 cubic inches larger. Almost identical.
                  76.77 vs. 77
                    Lee,
                    Thats awesome. I hope they will sound as good as yours do.
                    I ordered some more veneer to do the Minions and Voxel in. I am going to do the baffles in that tiger stripe maple I have left over and the rest of the cabinet in the mottled Makore.
                    Should be nice, I hope... :p
                    Kevin
                    76.77 vs. 77
                    Classix II
                    OS MTM's
                    Digger 8 sub
                    Sprite Build
                    Wolf's PC Speakers
                      You need to drill the driver hole before you mount the baffle. With the baffle being 1/2" thick you are going to need to chamfer the back side of the driver opening to give the driver breathing room.
                        Sounds like a plan.
                        Now I have never chamfered anything before, what do you use to do that?
                        Kevin
                        Classix II
                        OS MTM's
                        Digger 8 sub
                        Sprite Build
                        Wolf's PC Speakers
                          One of these.
                          http://www.amazon.com/CMT-836-280-11...ds=chamfer+bit
                            Can that bit be used in a drill? Or am I limited to a router?
                            Kevin
                            Classix II
                            OS MTM's
                            Digger 8 sub
                            Sprite Build
                            Wolf's PC Speakers
                              Kevin
                              You're better off with a router. A drill is much slower than a router, plus it would be hard to hold to maintain a uniform cut. If you don't have a router, you can use a file; that would be on the slow side, but it will work. You can also use a Dremel with a sanding drum.
                              Mike
                              "We're speaker geeks, not speaker nerds. Nerds make money!" Marty H
                              Bismarck, North Dakota
                              My Current System: Jolida SJ502A, Squeezebox Touch, and Carmody Sunflowers
                              My Garage System:Marantz 2238B and Nano-Neos
