Help Identifying Horns
  • Help Identifying Horns
ID:	1187474Click image for larger version
ID:	1187472Click image for larger version
ID:	1187473I have four cast aluminum horns that I bought in a batch of tools and speakers from a music store that went out of business a number of years ago. I'd like to use them in some PA satellites that I'd like to toy around with, but have had no luck identifying which drivers will fit them.
    The OD of the horns measure 10.5" X 4". The "dome" of the horn measures exactly 1". They have three mounting screw holes, and these measure 1 9/16" (40mm) center to center.
    The numbers on the horns are 7106-9301, and 575232.
    Any guesses?Click image for larger version
    Re: Help Identifying Horns
    Cerwin Vega HF-6, Pyle, Hepner
    http://www.simplyspeakers.com/pyle-h...agm-d-417.html
      Thanks, Sydney!
      GeeDeeEmm
        Well, thanks to Sydney's excellent lead I've been able to locate tons of replacement diaphrams for these horns -- but I still haven't located a single driver that will fit them. I hate to ask for help again, but -- help! I'm not in urgent need for them, but I'd really like to toy with them in a project.
        GeeDeeEmm
          AFAIK these were only sold as complete horn/driver sets. The music store probably robbed the diaphragms out of them for replacements. You might be able to jury rig a 1-3/8" adapter to them, but the results are unpredictable, and you can buy a horn for the price of an adapter.
          www.billfitzmaurice.com
            Any 1" compression driver should bolt right up to them. It looks like it was a 3 bolt pattern horn and another hole was drilled to make it a 2 bolt pattern...if it wasn't, you can do that.
            http://www.parts-express.com/cat/hor...ers/33?N=12992 4294967118 4294964531&Ne=10166&No=0&Nrpp=16&Nrs=collection()/record[endeca:matches(.,"P_PortalID","1") and endeca:matches(.,"P_Searchable","1")]&PortalID=1
            Take your pick from the 2/3 bolt pattern horns. There are more with just 2 bolts.
              Thanks for the suggestions, guys.
              GeeDeeEmm
                Not necessarily. The standard drivers have a 2-bolt pattern at 3" on center or a 3-bolt at 2.25". The horns for these typically have both patterns (5 holes). What I see in the pic looks like a smaller BCD, typical of the "all in one" horn/driver combos that have 1" phenolic diaphragm drivers. The drive unit from one of the cheap "bullet" tweeters is more likley to fit.
                  I need three of these for my Model 808 rebuild if you decide to go another direction. Rob
                    Whatever direction he decided upon it took place four years ago.
                      Sorry. Those little beauties are long gone. Moved on to other stuff.
                      GeeDeeEmm
