Car Audio vs Home Audio
  • Car Audio vs Home Audio
    Does any know if the design approach for car audio speakers is "significantly" different, in any sort of way, from the design approach of home audio speakers? I ask because it is hard to find parameters for car audio speakers which make design more ambiguous.
    I assume these may be some of the differences:
    1. Designed for a more humid and harsh environment?
    2. Designed for infinite baffle enclosures?
    Please let me know your thought. I would like to use drivers which I have more knowledge of and can utilize more appropriately, but I am hesitant to put "home audio" speakers into a car and have them corrode and suffer from other unknown conditions that "car audio" speakers may compensate for.
    Thanks,
    Tony
    Re: Car Audio vs Home Audio
    +1.
    +1, meaning high Q. The final difference is impedance, often 2 ohms, to compensate for the low voltage power supply.
    www.billfitzmaurice.com
      in my experiences car audio drivers tend to be built a touch more rugged because of the environment. car drivers tend to be optimized for smaller enclosures to take advantage of the natural gains from being in a car.
      big difference between the two types i see anymore is power handling and excursion, that edge usually going to the car drivers, but there's nothing saying you can't use "home" drivers in a car per say.
        Both . . . and nobody, but nobody, cares about "imaging" or "localization" in a car. All reflections are "early", and cabin gain isn't just a "subwoofer" thing. The only "listening environment" in a house even remotely comparable to a car would be a (small) bathroom (except a car cabin is better damped). And because of the inherently high noise floor in a car nobody cares much about "dynamic range" in one either . . . as indicated by the overcompression in recordings of the kind of music typically listened to there.
        Different worlds . . .
        "It suggests that there is something that is happening in the real system that is not quite captured in the models."
          Car drivers tend to be optimized for smaller enclosures to take advantage of the natural gains from being in a car
          I have definitely noticed this when modeling car subs.
          I believe this is a result of the SPL fad.
          If no other significant design conditions are accounted for, I may give it a try (utilizing home drivers). However, giving the nature of the car environment, choosing and building crossover points and roll-offs is a bit intimidating. I assume measurements would have to be taken within the chosen car and at expected locations for all drivers to accomplish any decent result. I believe this is the other critical area car design differs? At this point, I can't afford to go active.
            You beat me to the punch, as my previous reply indicates. These conditions are definitely a concern.
            and nobody cares
            I may have to disagree, as I care ;)
              if i gather correctly you're contemplating full range?
                Yes, just a simple mid and tweeter with passive network.
                  god's speed. i've never gotten it to work/sound right which is probably more due to placement issues than anything. most component sets i've cracked open (car audio) tend to be xo'd (by my very basic maths) somewhere around 1500hz, something to consider
                  when it comes to mids/highs in a car, outside of the very serious SQ setups, the typical "kill it with fire" method is applied.
                    Deward you are either crazy or just ignorant of what serious car audio people do and can do in a car.
                    2 ohm speakers were pretty popular 10-15 years a go in car audio, not so much these days.
                    You will find car sets that were OEMed by Vifa, Scan Speak (Revelators), and SB Acoustics to name a few...and are the same or very similar to their home audio part numbers.
                    Sub enclosures have gotten smaller because amp power has gotten so much cheaper...so efficiency has gone way down to make the enclosures smaller, not to mention the cars have gotten smaller.
                      DEWARD is a fine name for a TROLL.
                      craigk
                        Really? For the front passenger or the back seat? 'cuz if you're driving you've got more important things to be paying attention to than the "imaging" of your music box (even if it was possible in a car environment). You know . . . the, um, "fly the f***ing airplane" thing . . .
                          well there are plenty of us that care enough to design and build car audio with at least decent imaging and dynamics. Reward your statements are as over generalized as much as the stereotype of an audiophile.
                          Car components more often than not are marketing hype and a "cool look". Why? Because of the targeted demographic. Most are not anymore rugged than home audio save the extreme SPL type drivers that are being tasked to withstand a couple if thousand watts of power.
                          Imaging a car system is a challenge and can get quite extensive and expensive, but not impossible. It will also only apply to the front seat locations and is usually centered for the driver. One does not need to be so concentrated on their sound that they can not be a cautious and defensive driver. For me just the opposite is true. A poor sound is more of a distraction to me.
                            I use these, installed in kick panel pods. Kenwood Excelon something-or-other deck, with an old-school Jensen KA5 amp. I use the crossovers on the amp to split high to low, and the passives that come with the components. A single 12" driver in a small sealed handles the low end, and real in-car response to below 30 Hz without any boost or bottom end EQ.
                            Imaging in a car very often suffers from door panel installations, as does time alignment. The kicks are about as far away as you can get, which really helps. Image is locked dead to the left center of the dash with a simple balance adjustment.
                            There are also advanced DSP units available that will time align and EQ everything, and they work superbly most of the time. Car audio is fun these days, but I choose to focus on other things these days.
                            Plus, when I want to - bass head satisfaction is a touch away, and there are several adjustments built into the Excelon that facilitate SQ at the source.
                              And, the most serious car audio SQ guys get about the backseat is small speakers for passengers, usually everything is faded to the front.
