3way design advice/crossover help!
  • #31
    Re: 3way design advice/crossover help!
    Originally posted by musica14 View Post
    am already using the vifa ne 180w, so I think that woofer be be perfect.
    what would you cross this over at?
    using usher 9950 tweeter
    2-300hz
    • #32
      can you hook a 8" in parallel with 10" in a 3way design or does it needto be 4way?
      • #33
        no (not successfully)
        • #34
          you can, but whats the goal?
          • #35
            really like the design of the Wilson alexia speakers, and they use both 8 and 10"
            • #36
              IME, the diy community doesn't try to copy commercial designs very often.
              • #37
                not trying to copy the exact design, obviously im no match for dave Wilson.
                but really like the sound they get with these speakers using the 8" and 10" together.
                • #38
                  maybe just 2 10" or 2 8" together would be better?
                  • #39
                    I have thought of those same drivers.
                    am looking at the Scanspeak Discovery 26W/8534G also.
                    if I did the Dayton would go sealed just don't know if it will go low enough that way.
                    what do you think ported or sealed?
                    speakers are strictly musical.
                    If you look on the PE data sheet, the f3 will be listed for sealed and for ported along with an appropriate box size. If you want sealed, I'd suggest an f3 of 45 hz or lower. For ported, I'd be looking for an f3 in the low thirties.
                    • #40
                      if using these drivers what would your crossover order suggestion be?
                      usher 9950
                      vifa ne 180w .58 ft3 ported
                      vifa ne 265w 1.08 ft3 ported
                      all 8 ohms.
                      • #41
                        usher 9950
                        all 8 ohms.
                        • #42
                          so you think 3rd order?
                          • #43
                            For what frequency?
                            • #44
                              2000 hz and 250 hz
                              • #45
                                "Slopes" aren't talked about or utilized that way anymore. That was the old "textbook" way of doing things.
                                Most of the time (at least in DIY) the "electrical order" is 2nd (sometimes 3rd on a tweeter). That, combined with a driver's "natural" rolloff tendencies (on either or both ends) most commonly yield a 4th order "acoustic rolloff slope". It depends how close to the drivers' natural rolloff you're trying to cross it, and what the drivers' impedance profile is doing in that region.
