Columbus Day Sale
Extended One More Day! Columbus Day Sale at Parts Express! 10/15/19 Click the Parts Express Logo at the top left of this page.
See more
See less
Can I build a small 2 way without using a crossover
  • Can I build a small 2 way without using a crossover
    I want to build a small all in one Lapai mini amp-speaker kit, since I cant find some cheap ipod speakers. I found a tweeter with a resistor PN 279-001. I was wondering if I can build a small 2 way speaker with this tweeter, ommiting the x over. I already have a pair of small 5.5" dayton woofers
    Re: Can I build a small 2 way without using a crossover
    No. The cheapest way is actually 1.5 way, just putting a cap in series with the tweeter to roll off the lows. Will probably sound like crap. The value of the cap will depend on the impedance of the tweeter and the rolloff frequency.
      No. You will be sending bass frequencies to the tweeter, causing it's destruction as soon as you turn the sound up somewhat. The 3.3 Ohm resistor is not going to give you any protection. At the most it will drop the output by a few dB. You need at least a cheap capacitor to block the lower frequencies (<$1). Spend a few bucks and make something decent out of it. What woofers do you have?
        Ok, so how do I go about that. I was thinking the 3.3 resistor would block the bass.
          Only way to go 2-way without a crossover is to use a piezo tweeter.
            Warning - this guy's hard to convince. DWYT
              Caps filter out bass. Resisters resist everything.
                OK so I'll see what the sales-tech guys tell me when I place my order.
                  It is unwise to believe everything one reads on the internet.- Benjamin Franklin
                    Darren, remember the advice you have received in the past from sales reps also.
                    You can have a 2way without a fully involved crossover. Use a piezo tweeter (the 3x7 isn't horrible). And pick a 6.5-8" woofer. You will need a couple of resistors to pad the tweeter down to match the lower sensitivity woofer. Look at Johnny Richards "Cabrini". It does have a fully involved crossover though.
                    Many of the " old school" speakers were essentially without a crossover utilizing a single cap on the tweeter. Bose was huge on this in their 201-601 series as well.
                      This is an update to an old classic Dynaco speaker, one cap.
                      http://www.madisoundspeakerstore.com...e-classic-a25/
                        Originally posted by isaeagle4031 View Post
                        Use a piezo tweeter...You will need a couple of resistors to pad the tweeter down to match the lower sensitivity woofer.
                        You can't pad a piezo with resistors, as it's a capacitive load.
                        www.billfitzmaurice.com
                          At least not easily, unless using huge resistor values. Even a piezo should be used with a cap to make it's response more predictable and manageable.
                          http://frugal-phile.com/piezo-XO.html
                            Then I guess JRs Cabrini's and the builds I did with them the resistor did nothing? The attenuation wasn't real? I applied an l-pad that brought the piezos level down to better match the woofer. Is this not padding or am I using the wrong terminology?
                              Not exactly, with the capacitive load the piezo represents, the resistor sets the xover frequency, as well as overall level. UNLESS the piezo had a resistor in parallel with it, it does not function as a typical impedance load driver.
