The Small Stack; a Micro 3-way.
  • joeybutts
    started a topic The Small Stack; a Micro 3-way.
    Disclaimer - Please do not come into this thread to let me know it "isn't worth it" or I "shouldn't do it." Please come in to be helpful, offer constructive criticism, and have fun.
    So I am taking on my first REAL build and design (with probably a ton of help and questions to/from the board and others). A way out in left field micro 3-way. Yeah. Micro 3-way. :eek: It's happening and there is nothing you can do about it! :p
    After some time weighing driver options and asking for some opinions - HERE - I've settled on the following drivers:
    EDIT: Final driver selection
    Tweeter : Morel MDT-39
    Mid : Peerless 830992
    Woofer : Tang Band W5-2053
    Summary:
    This build is being designed to be a desktop loudspeaker, no more than 4ft from the listening position. So some things may be compromised to accommodate.
    It all started with the Peerless buyout mid and my desire for a small 3-way design. I figure the paper cone mid should do very well handling the midrange and I know stereotypically Peerless is well regarded, so I can't imagine that I will be disappointed.
    I then moved on to the woofer. I know I don't want a subwoofer, I want this to be a true full range speaker and feel it can be since it will be within 3ft of me. I went with the new Tang Band offering that are supposed to offer nearly physics bending performance in small spaces on not all that much power. I sure hope that they live up to the specs.
    Then it was a toss up on the tweeter for myself. Nearly chose the Morel MDT12, but through nearly unanimous recommendations, went with the SB Acoustics tweeter.
    EDIT: After much more discussion, the driver selection and consideration of certain aspects of speaker design, the driver selection changed quite drastically. This is becoming an all out build. Oops. :D
  • andykriech
    Didn't NavyGuy build a nice small 3-way? i think it is in his signature...
  • howard
    http://techtalk.parts-express.com/fo...rs-small-3-way
    I made and like these. There are $20 in drivers but a well integrated crossover.
    No infractions, just my recollection. One of the reasons for the theme was that there are not a lot of small 3-ways in the DIY sector. Most DIY 3-ways are large. As far as I know, nothing in the same vein has arisen since your last inquiry. When some of these builds take a few years from start to finish, it's not unheard of for minimal numbers to be built in a 4 year span- especially when it's not a more common approach.
  • mister_project
    There were a whole bunch of mini 3-ways designed a few years ago for InDIYana. Somehow I think I've replied to mister_project about this before....
    Yes, you did Wolf and I appreciate that. I wasn't trying to spam the forum and I apologize if me asking others or again at a later time is frowned upon. I have a hard time gauging how often new designs come up on the forums and was just trying to really see if there were any new and attractive ones popping up since I last asked or since InDIYana 2015 since that was so long ago. I was also hoping to get some advice or input on some of the options I listed in case I wasn't giving them a fair shake. Again, my apologies for any infractions I've committed.
  • mister_project
    What is your definition of "small"? If you google Sehlin Sound Solutions you can see his Hafnium's (pretty small at 0.38 cubic feet) and Zriconium's (not that small at 0.56 cubic feet).
    Small enough to fit into my built-in bookshelf (terrible speaker placement generally, I know) which means that whatever I end up building absolutely must fit into a space 23.5" H x 14" W x 14" D.
    I did see the Zirconiums and would say they're an option I'm considering. I'm less than thrilled about the 6.5" woofer for bass extension. When I first saw these I thought they were rear ported and was trying to figure out where I'd relocate things to. Looking again, I'm a bit confused on this detail since not much information is given from what I can see. If they were sealed that would alleviate my port relocation issue, but then again I'd be asking about actual bass extension with the sealed design. I took the Halfniums off my list because of the same concerns I have about the Zirconiums except even more so. The woofers are 5.25" which I just don't think I'll be happy with.
    I know I'm trying to cram a lot of design requirements into this. But like OP said at the beginning of this post, I have sort of a "you can't stop me" mindset in terms of small 3-ways, and especially for a bookshelf setup. I know it's not recommended by most, but it's the space I have to work with and I want a 3-way setup instead of a 2.1 for other various reasons I won't get into.
    I'm aware of a handful of designs that may work, but at first glance none of them really felt like a home run. Of course I, "want it all" so relatively good bass extension is important to me. It'd also be nice if I could buy the drivers and XO components for around $500. I'm skilled with fabrication and woodworking but have only built a handful of speakers and have mostly followed other designs. I'm not very confident or knowledgeable about the finer details of XO design. I'm fine with modifying existing enclosure designs a little bit to fit my physical space or relocate a port, but for this project I'm not really interested in major redesign of the XO for instance. Here's a few of the best contenders that I'm aware of:
    - 3-Way Classic Bookshelf: pretty much spot on with what I want and the 8" bass driver is perfect for getting bass extension as much as is possible. The sticking point is that the price of the components is a little bit more than I'd like to pay, and with shipping costs would be well over budget. If I ended up going with these, I'd have to be pretty confident these speakers were clear winners since they're almost twice the price of all other options.
    - Xenoliths: I like most of what I read about Wolf's design with a few exceptions. I do like the sideways orientation of the speaker because it'd allow me to move the shelf down in the bookshelf and have more usable space for well, books. The traditional speaker design with height being much greater than width is not very efficient in terms of bookshelf storage efficiency. People commented the bass was decent for a speaker this size, but the 6.5" woofer concerns me in terms of extension at least when compared to the 8" woofer in Travis's design above. Then there is also the issue with the side ports--I'd have to figure out how to relocate those on a baffle that already looks pretty full.
    - Silverbacks: Here's another set of speakers that looked really promising and like they might have met all my requirements. The 8" woofer and overall dimensions are spot on. However, I'm not sure how well developed these speakers were or if they rivaled other options in terms of SQ. Unfortunately, the Pursuit of Sound website no longer works and finding a ton of information of people with firsthand experience is difficult. It seems like they just dropped off the face of the planet. Maybe somebody on PE knows what happened...
    Here are some other options I've looked at too. The 6.7" - 7" woofers might be okay but seem less appealing than the 8" options above. However, I know it's not simply a matter of cone diameter for bass extension, but to a first order I've been using that as means to rank the options.
    - Latus1
    - Summits
    - Zirconium
    - Hypnos
    - Argon
    - Darpa Jr.
  • mister_project
    - Latus1
    - Summits
    - Zirconium
    - Hypnos
    - Argon
    - Darpa Jr.
  • a4eaudio
    Originally posted by mister_project View Post
    I've been looking for a small 3 way design I can use in my bookshelf and was bummed to read through this post only to see the ending. Was there ever any other "micro 3 way" style designs that resulted from this or other, independent efforts? The caveat being that since I want to build them, the drivers still need to be available..
  • mister_project
  • joeybutts
    Awesome. I'll build one sealed and one ported for testing. Love my bass but original intention was desktop/nearfield.
  • jhollander
    Really depends how you want to use them. IMO: desktop, bookshelf, and corner sealed is fine. Stand mount, go ported and full BSC.
  • joeybutts
    Found all my materials for this build (including waiting to be cut baffles) and will get to some cutting.
    Looks like my original plan was to build these sealed to keep the size relatively desktop friendly. Should I abandon and go ported? Or go with PR's?
  • joeybutts
    Ok, ok. Twist my arm. 😏
    Maybe next week I can make some sawdust.
  • kenny_k
    Joey, listen to John........ listen to John..........
