2x250 IRS2092 amp build
  • 2x250 IRS2092 amp build
    Finally got this done and playing. Very simple build. If I can do it, so can you. I used this amp modual from Parts Express. http://www.parts-express.com/2x250w-...board--320-313
    with a 45va Toridial form Antek.http://www.antekinc.com/an-10445-100...v-transformer/
    It was thought I might be a little HOT but all said and done it puts out 64.6 volts under a load. Whew!
    The PSU uses 8 per side caps from Apexjr. 2 bux per! 4700x 8 for 37000 per rail. I read a bunch but pretty much copied Hong's. I used a softstart module I got from ebay and a unit that turned 12vac to 12dc I bought from AJ. works like a charm to power a 12vdc fan and 12vdc truck light to show its on. Case is form Parmetal and was about $100. this is destined for my theater so I wanted it to blend. Feel free to ask questions.
    Re: 2x250 IRS2092 amp build
      BTW, nobody made a board big enough so I make my own from plexi.
        Cool Arlis. I like what you did. Total cost + $350?
          Probably closer to $325. The case added a lot and this can be done with a lower va torodial but the 800 was out of stock so I went with the 1000. 600 would do fine. This build was to be overkill from the start. With a home made wooden box and smaller Toroid, it could be built much cheaper.
            Very nice. I really need to edu-mah-cate myself on this stuff a bit more.
            Initial Success or Total Failure
              Originally posted by arlis_1957@yahoo.com View Post
              The PSU uses 8 per side caps from Apexjr. 2 bux per! 4700x 8 for 37000 per rail. [/IMG][/URL]
              You have them in series/parallel arrangement. That is 9400uF/'side'. Only parallel adds (doubles) capacitance. In series they will halve, but carry twice the voltage capacity.
                Awesome Lowell! I was going to ask you about the amp's progress, but I'm glad it's done. Did you paint the case, or did you buy it anodized black?
                Hong
                LM4780 Parallel Chipamp
                Sonata Soundbar Project
                  Anodized front, The rest is painted from the factory. Made all the holes with a step drill bit.
                    Are you sure about that. If so, then every PSU I have seen is wrong.
                    Its the same as Hong's http://techtalk.parts-express.com/sh...highlight=hong
                      That's nice looking Lowell.
                      Stuff like this gets my juices flowing...There are so many fun aspects to the speaker/sound hobby, and I'd like to dabble in all of it!
                      I have a question, is the piece of plate metal between the Transformer and the amp in the second pic above there for some type of shielding, or as a heat shield from the amp?
                      TomZ
                        Wolf is right with his capacitor math.
                        Sehlin Sound Solutions
                          TomZ
                          Thanks Tom.
                          Yes, copper shielding between the Transformer and amp. It generates no sound at the speakers without input.
                            Very nice! IIRC, Neil Davis said the 2092 designs were cleaner than most of the other
                            Class D chipamps. Plenty of power for demanding sources like AC/DC and Wagner.
                            Tangband W6-sub
                              Here is another example. These are polarized caps. I used two of them with the + of one and - of the other joined to form the 'ground' for the amp.
