Summer Vacation III: Next phase
  • #31
    Re: Summer Vacation III: Next phase
    New Day, new measurements. BTW, if you use a 30uf to protect the tweeter, take it out when you measure the other drivers!
    Anyway,
    • #32
      Here's a question, which impedance chart can one take as true? Why does the summed chart not reflect the changes in the tweeter chart?
      • #33
        Actually it looks as if it does. In both graphs the tweeters impedance drops below 6 ohms at 1k, bottoms out at 2.5k and ends at 5 ohms at the 20k point. Both graphs reflect that (to me at least).
        • #34
          I see 2 ohms on the summed, don't you? Am I missing something here?
          • #35
            No, it looks like 2 ohms to me too.
            Kenny
            http://www.diy-ny.com/
            • #36
              I think the turquoise line indicates the compensation its just not reflected in the summed.
              • #37
                Turquoise is the line BEFORE the xover is applied, but after the compensation. The red line is everything. You'll see the red line in the system impedance looks the same as in the tweeter pane.
                System and tweeter both dip to 2 ohms.
                • #38
                  This was what I was trying to say...poorly worded on my part. Sorry Lowell.
                  M.
                  • #39
                    That's ok Marty, I'm still a bit confused. As I add resistance, the turquoise line goes up but I should ignore this and only believe the red line that stayed in place.
                    This would be a great time for Jeff Bagby to drop in.
                    • #40
                      John H
                      • #41
                        Originally posted by jhollander View Post
                        Not sure what to use that information for so I turn it off.
                        I use the impedance comp curve in the driver pane to tweak the values of RLC circuits.
                        Craig
                        I drive way too fast to worry about cholesterol.
                        • #42
                          What do you want me to chime in about? Wolf already explained things. Your crossover is causing your tweeter impedance to drop to two ohms, that's reflected in both the red line in the tweeter impedance plot and your final summed impedance. This drop is caused by the Q of the high pass circuit you are using. It must have some peaking near the crossover point. I would recommend changing the high pass circuit to raise the impedance.
                          • #43
                            Thank you for your gentle reply. Does anybody else know what the turquoise line is for? Should it just be turned off as if it is no use at all? Is there an good time to recognize it?
                            • #44
                              My understanding of the electrical phase requirements is weak, but I'll repeat what I've been told on this forum at some point. That line is the electrical phase, and optimally you'd want an impossible flat line to make it easy to drive for the amplifier. However, just trying to minimize the shifts and keeping it from +/- 30 should be enough. I normally don't worry about it too much unless some wild swing occurs. You have something close to that between 2 and 4 khz in my opinion, but its nothing too insane.
                              Audio: Media PC -> Sabre ESS 9023 DAC -> Behringer EP2500 -> (insert speakers of the moment)
                              Sites: Jupiter Audioworks - Flicker Stream - Proud Member of Midwest Audio Club
                              • #45
                                That's the "tweeter + compensation" line. It is an intermediate step showing the effects on the impedance of any Zobels, L-pads, series resistors, shunt circuits, etc. It is sometimes useful in helping adjust the impedance before applying the high pass circuit.
