Adding Sensitivity
  • Adding Sensitivity
    Quick simple question.
    If you wire two drivers in parallel how does this effect Sensitivity. Say your tiring to match woofers to mids and you wire two 8 ohm 90 db woofers in parallel. Do you get a Sensitivity of 90 at 4 ohms or will you get something a little higher like a 92 db at 4 ohms.
    Thanks for your help,
    Ed
    Re: Adding Sensitivity
    96 db at 4-ohms at 1w/m
      If the 90-dB sensitivities of the 8-ohm woofers were measured with a 2.83-volt input, which happens to be a 1-watt input, wiring them in parallel will result in a sensitivity of 96 dB with a 2.83-volt input across their 4-ohm impedance, which is a 2-watt input.
      Paul
      Ed
        If you double the cone area (i.e. wire two speakers), you get +3db.
        If you halve the impedance while the voltage stays the same, then suddenly 2.83v goes from 1 watt at 8 ohms to 2w. Since you doubled the amp power, you get +3db.
        +3db from doubling the cone area +3db from doubling the amp power = 96db
        DARPA Jr - 2015 InDIYana Winner - RS180-8 + RS100P-8 + ND25FA
        The Aria's - RS150-4 (or RS150-8) + XT25SC90
        The Mariposa's - TEBM65C20F-8 + ND16FA
        The Canzonetta's - RS100P-8 and ND16FA
        AudioSource AMP-100 Mods OR Pyle PAMP1000 Mods
          Thanks a lot that really helps.
          Thanks Again,
          Ed
            http://www.audioholics.com/loudspeak...-basics-page-2
            I found this closer to reality when I did measurements with several combinations. Although my results were higher. Depends on the amp too. Would rather use actual measurements than elementary school math.
              For the post graduate course on sensitivity gain or loss check out my white paper starting on page 17.
              NFLAWP.PDF
              Jim
                It's easy to figure for a stand mount speaker. The woofers on a floor standing speaker really need to be measured to see how much boundary reinforcement you are getting from the floor.
                http://jaysspeakerpage.weebly.com/
                  I didn't realize they were teaching logarithms in elementary school nowadays.
                    LOL, here in New Mexico its not even part of 10'th or even 11'th grade math track. In fact it's a rare student who hasn't had calculus who I encounter that has even heard the term. Of course the problem extends to businessman and politicians as well who have no concept of how things grow (or decay).
                      That depends on what you use for a signal level. If it's 1 watt you'll get 93dB. If it's 2.83v you'll get 96dB. It's usually best to use voltage sensitivity, not power sensitivity, when making calculations.
                      www.billfitzmaurice.com
                        Presuming that was factious; unfortunately I have heard adults say that Algebra had NOT been a requirement for them - The concept of formula reduction was baffling; along with the relevance to the real world.
                          There are many adults that can't do even simple math, like addition or subtraction, in their heads, for instance to "make change", much less multiplication or division or percentages. Helps explain why so many people can't budget and amass huge debts, like from credit cards.
                          Paul
                          Originally posted by Sydney View Post
                          Presuming that was factious; unfortunately I have heard adults say that Algebra was not been a requirement for them - The concept of formula reduction was baffling; along with the relevance to the real world.
                            Sad but true
                            That reality is a serious issue - my opinion
                              Interestingly, I was just reading where a young mathematician has recently solved an Erdos Conjecture on gaps between Prime Numbers. It involves the following equation:
                              There are enough Logs in there to build a fire. ;)
