New Center Channel Speaker, need help on the crossover
  • New Center Channel Speaker, need help on the crossover
ID:	1191412Click image for larger version
    I am building a custom CC for the bedroom to go with Paul's Swope MTM's. I know he designed a specific CC for those but I wanted to be able to wall mount this CC directly below the TV. I am really hoping Paul will drop in and help me on this crossover due to his knowledge of the Swopes, but anyone's help will be greatly appreciated. I am still to green to tackle the crossover by myself and I'm not one of those guys that is to proud to admit it. I am studying everything I can to become more knowledgeable on this subject, but it's a lot to take in. In the mean time I hope to learn from your experience and help.
    The drivers are (4) of the Hi-Vi M4N's and the ND28F-6 Tweeter. I was hoping to follow the Overnight Sensations CC crossover type, a 2.5 way. The sealed enclosure measures 6" x 6" x 39" and is built from 1/2" MDF. The internal volume is close to .5 cubic feet. This should yield somewhere around 75hz by my calculations. The centers from the inner mids to the tweeter is 3.813, from outer mid to inner mid is 4.832. Let me know if there is any other information needed to design the crossover.
    I will post pictures of the progress as this project moves along.
    My "No-Name" CC Speaker
    Kerry's "Silverbacks"
    Ben's Synchaeta's for Mom
    The Archers
    The Gandalf's
    Re: New Center Channel Speaker, need help on the crossover
ID:	1163057Click image for larger version
ID:	1163058Click image for larger version
    If I did this right this should be a picture of the panels laying flat, followed by a dry fit check, and the last one is showing the removable rear panels for access to the drivers and crossover.
    The Archers
    The Gandalf's
      First stage of the glue process, I will glue the front to the enclosure after I cut the reliefs on the back side for the drivers to breath better.
      The Archers
      The Gandalf's
ID:	1163061Click image for larger version
ID:	1163062Click image for larger version
ID:	1163063Click image for larger version
        Here is my approach on what I think you guys call rebating the baffle. I cut plastic inserts for the router bearing to guide off of. This is probably overkill, but in this case I had four holes to rebate, and I got the same result on all four holes. Not to mention if I ever do any other projects in the future that uses the M4N drivers, I have the template finished and ready to go.
        The Archers
        The Gandalf's
          Finished glue up last night, still felt like I needed more clamps but this was all I had available. The goal today is prime and paint, I will post more pics after painting is complete.
          The Archers
          The Gandalf's
            Primed and almost ready for paint, the weather was perfect for this today. I've never shot a urethane paint before, this will be the first time, hopefully all goes well.
            The Archers
            The Gandalf's
ID:	1163126Click image for larger version
              Here's a couple of photos with the drivers sitting in the cabinet loose. The paint match is not spot on, but it's pretty close. I am going to build Paul's MTM's for the lefts and rights and stay with the same paint scheme. I will post another picture of this once I have it mounted under the tv to the wall.
              No one has chimed in yet with a crossover suggestion, not sure why unless I screwed up on the driver choices and a good crossover is just not feasible. I know the M4N's get a little nasty on the upper end but I thought it could be crossed below that to avoid it. If the drivers are the problem, could someone let me know why to help me better understand.
              The Archers
              The Gandalf's
                If you can trace the frd/imp files for each and post them I should be able to give you some input by the end of the week.
                -Kerry
                www.pursuitofperfectsound.com
                  Thanks Kerry, Parts Express has the frd/imp files for the M4N's on their website, so I wont have any problem getting that to you, but I'm not sure how to come up with the same for the ND28F-6. How does one go about tracing the file to come up with the frd/imp? Do I need a measuring device? Or do you just print the manufacturers spec sheet and plot the data manually?
                  The Archers
                  The Gandalf's
                    SPL Copy or SPL Trace are both free and can do it. I think trace does it mostly automatically.
                    -Kerry
                      OK, I will look into these this evening and get back to you with the information as soon as I can. Thanks in advance for the help, I was really starting to panic that no one was going to help. I know I put the cart before the horse by building the speaker without having the crossover designed. I promise I will continue my studies and eventually be able to design one for myself.
                      The Archers
                      The Gandalf's
                        Here ya go.....FRD & ZMA for the ND28F-6
                        These are via SPL Trace using Dayton-supplied graphs.
                        Good luck.
                        ND28F-6.frd
                        ND28F-6.zma
                        Bryan K.
                        Midwest Audio Club
                        Speedster | Sub Attachť | The Wildeman | Sean's NLA Towers | CO‹GAR, COUGAR II and CO‹GAR JR | Triton | Lithium | J-Boom | Trym MLTL | Docere MLTL
                          Good luck.
                          [ATTACH]53182[/ATTACH]
                          [ATTACH]53181[/ATTACH]
                          Awesome Bryan, thanks!
                          The Archers
                          The Gandalf's
                            Originally posted by Kevin K. View Post
                            [ATTACH=CONFIG]53174[/ATTACH][ATTACH=CONFIG]53175[/ATTACH]
                            Those look great.
                            How did you do the face of the baffle.
                              Originally posted by Dewmiester View Post
                              Those look great.
                              Thanks Dewmiester. I went to an automotive paint supply to find the color to match the M4N's. Once the enclosure was primed I sprayed the entire front of the enclosure with that color. After that dried, I masked the stripes with some 1/4" masking tape and masked the chamfers with 3/4", then proceeded to paint the entire enclosure in the black. After that was dry, peel the masking tape and there is your result.
                              The Archers
                              The Gandalf's
