DIY Flat Panel Speaker Love
  • #16
    Re: DIY Flat Panel Speaker Love
    Now if these panels behaved like piston drivers, there is no hope of having much bass. First, for a piston driver its output will fall off by 12 dB per octave below its Fs. So if the system behaves like a piston, below 224 Hz (the Fs spec for this transducer), your amplitude would be down 12 dB at 112 Hz and then down 24 dB at 56 Hz. Second, for a dipole radiator its output is a function of its width and will fall off by 6 dB per octave as you go down in frequency. For a 2' wide panel you looking at an 18 dB per octave or greater decline below 224 Hz. Thus don't expect a lot of low frequency output.
    It would help if we had frequency response data to assess how these panels perform. I'm interested in learning more about how they work.
    • #17
      Originally posted by piazzafatb View Post
      Can you elaborate???
      Hi Rich
      After your suggestions in my OB Hestia build, I would give a try to the panels when I finished my Hestia.
      Thanks.
      Lets just say back when I was a young budding hifi noob that was the forum I found, and subsequently followed the advice of the "experts" over there. The a$$ wiping and flushing of several thousand dollars down the toilet was a lesson well learned about the audiophool world. It did push me to learn way more about audio then I might ever have, being the simpleton paint slinging aircraft maintainer that I am.
      http://jaysspeakerpage.weebly.com/
      • #18
        Originally posted by Jim Griffin View Post
        I don't know if you can use conventional piston driver theory on these transducers but if it applies then let me state a couple of factors. First, for a piston driver its output will fall off by 12 dB per octave below its Fs. So if this system behaves like a piston, then below 224 Hz (the Fs spec for this transducer), your amplitude would be down 12 dB at 112 Hz and then down 24 dB at 56 Hz. Second, for a dipole radiator its output is a function of its width and will fall off by 6 dB per octave as you go down in frequency. For a 2' wide panel you looking at an 18 dB per octave or greater decline below 224 Hz. Thus don't expect a lot of low frequency output.
        Hey Jim,
        Yes, DML does operate on different principles. You can read a good introduction to Distributed Mode Loudspeaker technology here :
        http://www.tectonicaudiolabs.com/wp-...rt-Version.pdf
        Best regards,
        Rich
        • #19
          Looks like a fun little project. If I had time, I might give it a shot. Hopefully in 6 - 12 months I'll remember this. I would love to see photos of your project.
          - Ryan
          CJD Ochocinco ND140/BC25SC06 MTM & TM
          CJD Khanspires - A Dayton RS28/RS150/RS225 WMTMW
          CJD Khancenter - A Dayton RS28/RS150/RS180 WTMW Center
          CJD In-Khan-Neatos - A Dayton RS180/RS150/RS28 In/On Wall MTW
          • #20
            This are just test panels so absolutely nothing to look at now. However once the panels are framed up I will surely upload pics!
            • #21
              Here are a few more links on DML panels and speaker reviews on the Podium Sound panels as well as their website.
              http://www.phy.davidson.edu/FacHome/...Tflatpanel.htm
              http://www.podium-sound.com/index-A.html?menu=70836
              http://www.6moons.com/audioreviews/podium/1_2.html
              http://www.stereomojo.com/Podium%20....akerReview.htm
              Cheers!
              Rich
              • #22
                Originally posted by Chaz_H View Post
                I'd be curious to see distortion measurements.
                Hey Chaz,
                Meant to post this yesterday. There are distortion plots in the link at the bottom.
                Most panel speakers are not known for there low distortion (esp. low frequencies) but these apparently fair pretty well. Not outstanding by any means but reasonable.
                Listening to these panels are interesting and tell the real story. If you can get past the diffused sound (omnidirectionality) and a soundstage that is presented further back in the listening plane, the sound is quite good if not amazing at times. Because the panel surface is large, excursions are small and the panels sound "fast"... percussion and plucked strings are fantastic and instruments have a very natural tone if the panel material is good and treated properly. Dynamic shading is the best I've heard to date... able to resolve fine details. Just fun to listen too... have not gone to bed before 1:00 AM this week as I just can't turn off the music...
                http://www.phy.davidson.edu/FacHome/...l.htm#Heading3
                • #23
                  Originally posted by rmeinke View Post
                  Hey Chaz,
                  Respectable as you say. Nothing to really fault at all from that data.
                  And this would probably explain the recessed sound stage. Just a bit of EQ to bring up the range between 500 and 3000 would likely bring the stage up to the speakers where it belongs. Far better behaved than I would have guessed just giving them a cursory look.
                  • #24
                    it sounds very intriguing indeed. I wonder how distortion changes with the material used, or with the number of transducers. What about a speaker like this, where different panels are optimized for bass or treble production?
                    • #25
                      Hey Chaz,
                      Thanks for the post! I may have some of the exciters, and HD is right around the corner.
                      Tangband W6-sub
                      • #26
                        [ATTACH=CONFIG]53297[/ATTACH]
                        Yo Chaz, the link doesn't work and curious what these panels are. Assume they are the Tectonic Plates pro panels. If so, I've heard very good things about them and one of the reasons why I decided to try the panels in the first place. Someone uttered the words "audiophile" speakers so I was intrigued. And with the design choice of the Heil AMT tweeter in the panel I was inclined to believe the high praise.
                        • #27
                          Hey Pete,
                          Yeah, it is really hard to believe that an exciter stuck to a panel performs as well as it does. Crazy.
                          My panels do not measure like that as the panel material is different and who knows the number of exciters/positioning on the panels, etc. for the DML's measured above. I did EQ mine as flat as possible originally but the lack of presence and the feeling that the soundstage was distant didn't improve a great deal... so work continues.
                          Thanks for stopping by Pete!
                          • #28
                            Heck yeah Don... about $14 for a 4' x 8' 3/4 sheet of XPS and some wood glue and water and your set! HD will even cut the panels. I'd start with 2' x 4' panels. And don't forget to sand the sheen off the panels!
                            Later!
                            • #29
                              was having trouble with the forum earlier, let's try again:
Name:	audio exciter speaker concept.jpg
                              • #30
                                My guess is that these panels might be too small for bass reproduction, but then again, if a heavier material is used intentionally and relieved of treble content (with a crossover if necessary) it might work.
