Because Don Keele said flat CBTs work and researches said MAP arrays work. That's pretty much the only reason other than DMLs have the characteristics you mentioned.
DIY Flat Panel Speaker Love
Twelve actuators per array. The CBT24K has twenty four per array. The goal is a sound field not loudness. It is a sixty inch array so I could meet the 170mm center to center spacing used in the 2010 wave field synthesis paper with nine actuators. I used twelve actuators because it matches Don Keele's transducer ratio in his arrays. Hopefully, a MAP CBT array can be created using fewer actuators.
Originally posted by bradley.s View Post
I'm shooting from the hip on that issue. I'm hoping my low volume level listening requirements will mitigate the majority of the problem. I'm also going to lean heavily on DSP. All the research I've personally seen investigates homogeneous single layers like a single sheet of aluminum or they use foam sandwiched with paper. The panels I'm going to try are hacked together. I have no idea what the internal dampening is on these things. It's a crap shoot. In addition, my geometry is also way off. I'm using very narrow panels relative to typical DMLs. With regard to normal DMLs, mine are a freaking mess.
What I'm hoping to accomplish is a CBT polar response in the 500hz to 6,000hz frequency range. CBT seems easy to handle below 500hz and hard to do above 6,000hz. If I can get the bulk of the frequencies working I can build a separate DML to handle below 500 and either forget about frequencies above 6,000 or try to figure out an alternative.
Originally posted by Unbiasedsound View PostSound field? Is that like sound stage?
Imaging and sound stage illusion rely on how you control the sound field.
No. Just control over the sound dispersion. Floyd Toole and Earl Geddes use different sound field controls (waveguides in Geddes' case, speaker position in Toole's) to create the illusion of a sound stage. A siren might create an omnidirectional sound field to alert everyone in all directions. The problem most of us deal with in this forum is sound field control in small rooms, our homes. We have to deal with reflections and physically long low frequency waves. Pro audio guys would deal with different problems because they might be in large rooms like auditoriums.
In the Maps article the only thing I agree about it is using some dampening properties....What I disagree with is that more exciters don't mean less room reflections.
Not sure if this has been posted before.
An attempt to create a bass DML, 40hz. They are seemingly successful to some degree and it seems to use techniques that have been discussed here before: https://web.wpi.edu/Pubs/E-project/A...er_Stabile.pdf and its relatively easy to read and understand...
Nice find geosand and bonus points for ease of comprehension.
This one sentence tells me what I need to know about multiple exciters vs one exciter per panel as NXT is probably the best known contributor to distributed mode loudspeaker technology. They had big plans for its implementation. "This technology, developed by now dissolved company NXT, involved placing surface exciters in positions along a panel that correspond with that panels resonant frequency" (Zielinski, Obiora, & Sansoucy, 2018).
Ok, these guys read my experiment with the panels. The wood frame holding the panel in with the aid of window seal foam ... where's my name in the reference section?
Reference
Zielinski, D., Obiora, O., & Sansoucy, D. (2018, April 25). Development of a Resonant Panel Speaker[PDF]. Worcester Polytechnic Institute.
Originally posted by Kornbread View PostNice find geosand and bonus points for ease of comprehension.
Reference
This report covers the development of a walled mounted, low-profile speaker system. A format that
could be hung from a wall in a way similar to a painting, and the capability to hit low notes. While a small number of speaker manufacturers have created dimensionally impressive
models, they are almost all very expensive or have limited frequency ranges, leaving a gap in the
sector for more affordable speakers that can achieve an ideal range.
You really believe the works he CITED are the only places his knowledge came from?.....I wouldnt doubt for a second that he read this thread or any other thread on any other forum pertaining to DML technology...most wont cite a forum because its not a scientifically based study but credit should be given where its due. If 5 years from now another scientific study on DML's comes out and they mention the Karsonator technique you will all know he got that technique from me. LMAO
Now like I always ask of those articles is where are there DML panels? Who has heard them? Who has built them? What have they been compared to?
This is one of the reasons DML's have very little to no microphone feedback.
