Vifa XT25TG30-04 vs XT25BG60-04 measurements
  • Vifa XT25TG30-04 vs XT25BG60-04 measurements
    Just frequency response and distortion
    All measurements taken with the tweeters in an enclosure from 4 inches away. No crossover. The mic and enclosure were not moved while the drivers were swapped out.
    XT25TG30 at roughly 100db
    XT25BG60 (double magnet version) at roughly 100db
    Response overlay of both drivers
    Obviously, response is nearly identical between these two tweeters. I had to bump the XT25TG30 output by 1.3 decibels to get the output to be almost exact. 2nd order distortion is lower on the XT25BG60 from 1k through 5k, and 3rd, 4th, and 5th order is lower in the 1k through 2k range. Not much difference between the two, but enough for me to use the XT25BG60 unless building a design that already uses the XT25TG30. (Zaph's ZD5, Wolf's ScandiVifa, Troels Ellam XT)
    Being defeated is often a temporary condition. Giving up is what makes it permanent.
    Merlot
    Scanspeak Revelator R2904/7000's,
    Scanspeak Revelator 15M/4531K00's, Dayton RSS265HF-4's,
    MiniDSP 2x8, class D amplification
    Sennheiser HD650's
    Re: Vifa XT25TG30-04 vs XT25BG60-04 measurements
    Both drivers again at just over 110db.
    XT25TG30
    XT25BG60
    Response overlay
    Merlot
    Sennheiser HD650's
      I wonder how the Scanspeak R2604/832000 compares?
        Measurements look terrific, as expected for such a praised tweeter. Thanks for sharing this data. One quick question though, when you provide SPL level is that measured at the mic or a standard distance such as 1M? I am assuming the mic but I figured I'd ask to confirm.
        Audio: Media PC -> Sabre ESS 9023 DAC -> Behringer EP2500 -> (insert speakers of the moment)
        Sites: Jupiter Audioworks - Flicker Stream - Proud Member of Midwest Audio Club
          I wonder if two of the same tweeters would have a FR as close.
          John H
            Crazy, huh? And these are old XT25TG30's that were compared to the new XT25BG60's.
            Merlot
            Sennheiser HD650's
              4 inches from the tweeter diaphragm. It's a UMIK-1 microphone with the calibration file loaded into the software. According to what I've read, SPL readings are accurate without any other calibration necessary.
              Can anyone confirm this? It seems too good to be true.
              Merlot
              Sennheiser HD650's
                Well that is only 4 inches, so at 1M 110 would be: ~90 db according to my calculator. Measurements seem to be valid to me for that SPL. I didn't know the Umik was good out of the box (with cal) for SPL amounts, nice.
                  Let me try to find where I read that. I'll post a link.
                  Merlot
                  Sennheiser HD650's
                    the SS measure a little better
                    craigk
                      .....and in this thread, assuming JohnM is the guy responsible for REW, he says that as long as the calibration file is downloaded from the minidsp website (with "sens factor" in the file), and the version of REW is at least version 5.01 (BETA 14 or newer according to the minidsp website), you're golden. No other calibration is necessary.
                      http://www.hometheatershack.com/foru...uiet-room.html
                      Merlot
                      Sennheiser HD650's
                        How is this relevant to the topic?
                          Because it's the Scanspeak version of the same tweeter, but with a few added tweaks IIRC.
                            if you read post #3 some one ask how the SS version of this driver compared to the Vifa version.
                            craigk
                              Accept my apologies.
