Problem with solid wood baffles
  • Problem with solid wood baffles
    I was given these cabs made out of solid walnut
    Note the crack that extends the entire length of the baffle
    A cautionary example of what could happen.
    Re: Problem with solid wood baffles
    This started to happen to my pine baffles. I injected gorilla glue and it stopped. I skived off the expanded glue and touched up the stain.
    http://jaysspeakerpage.weebly.com/
      Not what I want to see as I'm working on solid mahogany baffles today.
      http://www.diy-ny.com/
        What a bummer. I've made a bunch of solid wood baffles in the past couple years. Hope they don't start exploding on me.
        Was that baffle glued to the rest of the cabinet? I think screws with some room for expansion is the recommended attachment approach?
        You gonna repair them?
          I haven't decided if I'm going to attempt repair; I thought a friend who is building a music studio/man hut might want them.
          A bit contingent on his decision, otherwise low priority.
          Some minor foam surround tear on one driver, otherwise they still work and sound fine as is; and much better relieved of bass reproduction - hooked to an active subwoofer.
          It's been a while but I believe ( and they appear ) glued ONLY - haven't popped out the drivers and done an exploratory.
            Yup. That's what happened to one of my Sunflower baffles, which were made of solid Oak. I had been hoping they would be immune to that kind of spilitting, since they were from 50 year-old reclaimed shelving. Nope.
            Twitter: @undefinition1
              I've been using speakers made with solid wood panels for over 12 years without issues. But I only use solid wood for the side walls and the front or rear baffles. Only well dried wood is used and typically pocket screw fasteners for larger panels or biscuits are used.
              My inclination is that the baffles have the most machining and stresses from mounting drivers and such. Hence, the baffles are most likely to split so I avoid that potential problem.
              Jim
                It does not matter how old the wood is or how well "seasoned", acclimated or dried. Moisture gain/loss will make make solid wood move. If restrained, something will give, somewhere, eventually.
                ~99%
                  Paul, you can use this to your advantage. A guy can use some India Ink and a small artists paintbrush to fill the backside of the split. The flowing Ink creates a black seam looking totally skippy. I've never done it with oak, but on darker woods it really looks pretty darn good. I imagine the average Joe would consider it to be a normal thing and woulnd't even notice the split. All the best, Mike
                    Wood will expand and shrink in response to humidity changes in the environment. The wider the plank, the more pronounced the expansions. No amount to finish will stop it. it may slow it down but it will still change. It is just nature. I learned this the hard way. Now if, you fill the crack with something else and then it shrinks again due to moisture loss, the wood will have to move or crack somewhere else.
                      Oh crap! Don't tell me this. I just put on the finish on a couple of Paduak baffles for a pair of Caritas that will be a wedding present. Luckily, I have till August to see if any bad stuff happens.
                        Are these hardwood baffles glued to an MDF sub-baffle?
                        A mains
                        The Ventures
                        Open Invit8tions
                        RSR
                        Sound Troopers
                        Acorns
                        442
                        DGBG's
                        The Monuments
                          This looks like one piece side slab cut with a large amount of sap wood which IMO is not very stable.
                          John H
                            Anytime you use hardwood you should go into knowing the enclosures are not going to last forever. I have built several hardwood enclosures and I know they may split or crack. If I can get 7-10 years out of it I am satisfied.
                            The Madeleine
                            The Roxster
                            Swopes 5.0
                            Acoustic Panels
                            Living Room Make Over
                              [ATTACH=CONFIG]54911[/ATTACH]
                              [ATTACH=CONFIG]54910[/ATTACH]
                              How wide is that baffle? I've had an oak baffle split on me at 9" wide, but had good luck with baffles narrower than that.
                              Dan
                              _____________________________
                              Tall Boys
                              NRNP Computer Sub
                              The Boxers
                              The Hurricanes
                              The Baronettes
                              Conneccentric
                              UX3
