Re: BBC-style thin-walled cabinets vs. tight bass?
Here is a cabinet resonance story I recently experienced. Two Human Speakers 005 woofers were purchased and installed in a pair of Fourier 8 cabinets. The cabinets are quite robust and braced front to back and side to side.
WT2 tests on the woofers produced very smooth imp./phase curves. Many woofers of other brands I've tested in the 8 to 12 inch range typically have a notch that occurs in the curves around 1 kHz which shows the woofers elect. response to cone edge issues manifesting themselves; even at the low voltage testing normal with WT2.
With the woofer fitted into the Fourier 8 cabinet with the port plugged to convert the cabinet to acoustic suspension, another WT2 test was done (see below). Here we see an impedance & phase spike around 150 hz. It's a similar kind of thing Atkinson finds on many of his speaker tests, including the Harbeth and others. The spike clearly was not present in the free air test shown above. I connected a function generator and found I could feel a resonance appear around 150 hz. and dissipate when freq. was increased.
I wondered what sonic effect the clearly evident resonance could have on the woofer's response so I ran a near field response test (see below). No crossover components were involved with this test. The response is quite impressive and devoid of a ripple around 150 hz. and with a complete lack of cone edge breakup mode spikes above 1 kHz.
I concluded as Atkinson has in many of his reviews that although cabinet resonances can show up when an impedance test is run, most are not to the detriment of the overall speaker's sound.
