The Chorales - An Usher / Vifa Project
  • The Chorales - An Usher / Vifa Project
    Well, I promised my wife - and myself - that I wouldn't buy another pair of drivers until I started using what I have in the closet. So, in order to buy more drivers, I have to put together a couple of projects. Having just finished the crossover for the Renditions, I was itching to breathe some more saw dust. I had a pair of Usher 8945A woofers and XT25 tweeters that I acquired a while back from a couple of the members here, so here we are. This combo has been done many times in the DIY community, but who cares? I'm going to build myself another pair of speakers because I don't have enough. Hehe.
    Day 1.
    Broke the woofers in overnight and determined T/S parameters, then loaded them in BassBox Pro to model the box, which volume turns out to be 0.6 cu.ft (17" H X 8" W X 13" D), tuned at 40Hz, with a F3 of 45Hz. The vent is 2" X 7".
    3/4" MDF is used, and the pieces are ready to be glued.
    LM4780 Parallel Chipamp
    Sonata Soundbar Project
    Re: The Chorales - An Usher / Vifa Project
    Day 2.
    Just gluing away. In the mean time, I went to Zaph Audio to look at the measurements of the Ushers and the Vifas to find the best crossover point.
      Day 1.
      Broke the woofers in overnight and determined T/S parameters, then loaded them in BassBox Pro to model the box, which volume turns out to be 0.6 cu.ft, tuned at 40Hz, with a F3 of 45Hz. The vent is 2" X 6".
      What else do you have sitting around in the closet not being used? Nice!
      My "No-Name" CC Speaker
      Kerry's "Silverbacks"
      Ben's Synchaeta's for Mom
      The Archers
      The Gandalf's
        Wow
        Sausage With Meat Sause, Please
          Day 3.
          Boxes completed. Interior lined with acoustic foam. Vent installed using Home Depot PVC pipe (2-3/8" OD), and glued in place with epoxy. The hole was cut with a Milwaukee 2-3/8" hole saw, so the fit was perfect.
            Day 4.
            Baffles routed to countersink woofers and tweeters. Woofer holes chamfered and screw holes reinforced with birch plywood. Additional bracing added to baffles. Finally, baffles glued to boxes.
              Day 5.
              3/4" roundover applied to top of box and to vent hole. This is what the project will look like before being finished. This weekend, I will mount the drivers and proceed with near field and far field measurements, then model the crossover.
                Day 5.
                Nice box design.
                craigk
                  I like the look. Looking forward to seeing more
                  -Kerry
                    I really like the way you dressed up the box with the added sides. I, however, would have considered a floor-standing mass-loaded or tapered TL for these woofers (I used an 8945A in my TL Cavatinas).
                    Paul
                      Nice Hong! What's the plan for the finish?
                        I made the same promise to my wife, but I find that I can distract her for a minute when the UPS driver
                        shows up, then the new drivers are safely in the basement.
                        Nice work!
                        Tangband W6-sub
                          Ooooh! Nice! Please keep us updated with pics.
                          Being defeated is often a temporary condition. Giving up is what makes it permanent.
                          Scanspeak Revelator R2904/7000's, Scanspeak Revelator 15M/4531K00's, Scanspeak Revelator 22W/8857T00's, Eminence NSW6021's.
                          MiniDSP 4x10HD. ICE Power amplification and an iNuke 3000.
                          Sennheiser HD650's powered by TEAC amplification.
                            Thanks everyone. The cab will probably have a black satin finish, and the sides will be real wood, but I don't know which kind yet.
                            Paul, good idea, that will give me an excuse to buy more drivers to try out a TL. Can I see a pic of the Cavatinas? Thanks.
                              Sure, here it is:
Name:	Cabinet finished.jpg
                              And, here's a cabinet drawing:
Name:	Cavatina Cabinet Tri-view.jpg
                              Paul
