Hamster Habitat Sub
  • Hamster Habitat Sub
    My last setup in the Ranger was pretty wild and intense, but made me realize what I enjoy most about a subwoofer; low low impact. When I had the eD 13A in my truck it was the most enjoyable....except for the lack of leg room. :p So went to the four 12's, but it just lacked the low end I wanted.
    So in comes a custom one of three supposedly protoype subs by Thilo at the former TC Sounds. Reminds me a little of the 13A I had but actually nothing like it.
    Details -
    Composite cone and cap
    8-layer flat aluminum coil
    Full copper TC9 proto motor
    Solid mid-Q driver with low Le and lots of xmax
    2.75" slug stack
    Dual 2 ohm
    http://www.caraudio.com/forums/subwo...tc-sounds.html
    So as is always the struggle with my Ranger....space. I've been trying to keep the passenger seat fully functional and I'm pretty sure I have failed four times now. :p This time is guaranteed to be a success.
    So the recommended enclosure was 1.8 cubes at 27Hz with about 31 sq in of port. When I simmed it showed a little wiggle room down to about 25 sq in of port, so I was planning on going with a 6" port but there was physically no way to get it in there. So I kicked around ideas and some rough mockups showed that two 4" ports should work. Of course each needed to be 49" long. :p I love crazy builds.
    So begins the fun of a Std cab Ranger build.
    Re: Hamster Habitat Sub
    Wow, I could never keep all that clear in my head.
      Wow, seems like half the volume is port tubes.
      John H
        Holy Cow!
        That's a lot of port! And the voice coil looks like it was made with Romex! That is some low gauge wire there.
        Curious, what's the box volume minus the ports? You sure needed to get creative to get that much port in there, nice!
        TomZ
          Thanks fellas! The port was definitely a challenge, but I really wanted to use PVC instead of a slot.
          I recalculated everything this morning....
          Gross internal volume = 2.3 cubes
          Ports = .6 cubes
          Driver = ~.08 cubes
          Bracing = negligible
          Net internal volume = 1.6ish cubes.
          The nice thing about the way I built it is that the couplings are on the side of the box and the ports extend out, so I can change the tuning of the box with a max tuning of 34hz. The way I built it tuning should come out around 27-28hz. I was hoping to get the net volume closer to 1.8 but that caused more headaches than necessary with the external ports and I've already used all the space I can for the enclosure itself.
          I should end up with an F3 of 24hz, a +1db peak at 31hz, anechoic. I think the small cab of the Ranger helped boost the sub 40Hz when I had the 13A in there so I should get a bit more reinforcement down there. :D :D
          I'm excited to see how this compares to the 13A.
            Quick question....how do you figure tuning if one port tube is shorter/longer than the other? Just curious how it would affect the response....
              I may be wrong, but the only way to do that is with an impedance sweep.
              LM4780 Parallel Chipamp
              Sonata Soundbar Project
                Average length of the 2 ports will be actual tuning length of both ports.
                  Man Joey!!!! I could just see you sitting around the firehouse doing curls thinking, "I am going to turn that fire pole into a port." Awesome creativity and excited to see the end result.
                  If we all reacted the same way, we'd be predictable, and there's always more than one way to view a situation.
                  What's true for the group is also true for the individual. It's simple: Overspecialize, and you breed in weakness.
                  It's slow death.
                  //Burn n' Die//Dream Weaver//Maximus//ABC Bookshelf Speakers//Dayton Twin Towers
                    I cannot wait to get a report on how this turns out.
                    Hurry up.
                      Those hamsters are in for a nasty surprise. I hope they are wearing their hamster helmets.
                        Why put the port tube in the box at all? Wouldn't it be easier to just run it external, behind the driver's seat, for example?
                        "It suggests that there is something that is happening in the real system that is not quite captured in the models."
                          First of all -
                          I am in total awe, I could never attempt a design like that - ok, maybe with a nice Sketchup model, maybe.
                          Second, I love my TC Sounds sub, but I wish they would do a better design for breathing with that basket.
                          Makes it more difficult to get your baffle correct.
                          Third, sorry, you're going to have to redo the PVC, one of the pipes is 1/4 inch shorter (just kidding)
                          Fourth, you'll probably blow the windows out of that Ranger!
                          Tangband W6-sub
                            Shake rattle and roll....your side view mirrors will shake so much that you will have trouble seeing the cars......seriously :eek:
                            NLA
                              That's what I was thinking.
