OT: How loud is an airplane?
  • OT: How loud is an airplane?
    Boeing 737-700 (SWA) row 20 of 24 -- well behind the wing -- seat A -- window. iPhone "SPL Meter" C-weight
    Takeoff roll 105dB - peak 109
    Climb to FL390 95dB
    Cruise 92dB
    How many passengers were wearing earplugs? Me!
    Bob
    Re: OT: How loud is an airplane?
    Climb to FL390 95dB
    Cruise 92dB
    At what frequencies? It must have been below 40Hz, otherwise conversation would be impossible. I've measured subs at over 100dB at 15Hz, and if not for seeing the result on the meter I'd have been unaware that there was any sound at all.
    www.billfitzmaurice.com
      Didn't think to do a spectrum. A-weighted was down ~3dB. Talking with neighbor was a bit difficult. The most apparent noise is the wind noise.
      Bob
        I kind of have to wonder if the air from the above vents was messing with the readings. I know it gets loud, but I find close to 100db to be reaching painful levels, or at least very fatiguing levels that I don't want to listen too except very short term. If it was just sound levels peaking at 109db, I'd think that would hurt and cause hearing damage and would not be allowed.
          As a frequent flyer, to me your measurements seem a little high, but plausible.
          I have a set of Shure Noise Isolation Ear Buds that I typically wear. These are the type with a built in ear plug. I'll use them even if not listening to music. I often wonder how people wearing regular headphones and turning it up over the engine noise are not deaf.
          - Ryan
          CJD Ochocinco ND140/BC25SC06 MTM & TM
          CJD Khanspires - A Dayton RS28/RS150/RS225 WMTMW
          CJD Khancenter - A Dayton RS28/RS150/RS180 WTMW Center
          CJD In-Khan-Neatos - A Dayton RS180/RS150/RS28 In/On Wall MTW
            Have never measured the actual loudness, but I know it approaches quite fatiguing for me on many flights.
            That all encompassing "Roar" of wind and engines, is not literally painful, but quite tiring and annoying.
            The sound of Shop Vacs all around and not being able to get away is my issue.
            are smaller jets quieter?
              I do not know the answer for sure, but I would say far above deep bass, more in the several hundred hertz area.
                I used to work at a international airport and the big jets on the tarmac are around 200 db. I had to have special headphones to protect my ears. It also helps to be in front of the plane as it is not anywhere near as loud. But from behind I was told it would measure 200 db.
                Now that freakin loud!
                Kevin
                Shaken, not stirred...
                Classix II
                OS MTM's
                Digger 8 sub
                Overnight Sensations Center Channel
                Sprite Build
                Wolf's PC Speakers
                Minions III with Voxel Sub
                  Kevin
                  200db... Are you sure about that?
                  http://listverse.com/2007/11/30/top-10-loudest-noises/
                    That is what we were told in training. We were told 200 db and to ware our headphones while the fans were spinning on the planes to keep them on as there were other "sounds" coming from the jets that could damage your ears, not just the loudness.
                    They had everyone pretty scared about their hearing.
                    Kevin
                    Classix II
                    OS MTM's
                    Digger 8 sub
                    Sprite Build
                    Wolf's PC Speakers
                      The air gets non-linear at 194, but a shockwave could be over 194.
                        Since my "SPL Meter" was on my knee, sort of hidden (All electronic devises off) I doubt it the air vent was contributing much.
                        During takeoff roll, the noise level IS near painful.
                        Remember I said I was behind the wing. The SPL will be less ahead of the wing and ahead of the engine exhaust.
                        Wikipedia says a jet engine at 1 meter is 150dB
                        Bob
                          I measured a take off once, don't remember where I was sitting or what plane it was, (a380?) but I think it was about 90db takeoff and 85 cruising. Don't remember what weighting I used either.
                          Melby Audio - Flat Pack Speaker Kits
                            No way. An average jet at take off is 180dB, and if you were close enough to it for it to be at that level the turbulence would send you across the runway. A Saturn IV was estimated to be around 195dB.
                              We just got home from Atlantic City , while waiting for our plane two F-16's (? the small, fast, loaded for bear ,the ones that escort Air Force One ) landed ,then another set then another set , guess they only come in a two pack ,we assumed they only stop there to re-fuel because they leave shortly after landing ,it was quickly obvious on their take off that they are not restricted to meet the same noise level as commercial airlines ,these things were loud ,really loud ! you would not be talking over these I promise you that !!!!!!!!!!!!!!!!!!!
                              donc
