How low can I / should I cross the MDM55?
  • How low can I / should I cross the MDM55?
    Scored a pair pretty cheap on eBay. Have you guys heard these crossed low? How low and how do they handle it?
    Dan
    _____________________________
    Tall Boys
    NRNP Computer Sub
    The Boxers
    The Hurricanes
    The Baronettes
    Conneccentric
    UX3
    Re: How low can I / should I cross the MDM55?
    800hz would be about the lowest I believe. Maybe 650hz. As I recall, the response drops like a brick on the low end. That combined with the baffle effects will pretty much limit it. Rick Craig or Wolf would be the guys to ask. I had a pair about ten years ago, so I'm going on old memories.
      Rick Craig xoverd the Cantilena about 1k.
      Bob Cordell xoverd at about 1.2k.
      I think 900+ was where most were preferable, and 800 at the maximum lowest.
          In my canTiLenas, the MDM55 is crossed at ~750-780 Hz, and even though I've seen suggestions, perhaps actual uses, it can be crossed at 500 Hz, that's too low.
          Paul
            Paul
            My apologies. I thought sure it was 950 in the Cantilenas.
            And I don't think I would recommend lower than 800 for any use.
              No problem, Ben. With an Fs of 380 Hz and an Xmax of 1mm peak, crossing below twice its Fs isn't a good thing.
              Paul
                Cool guys, thanks. I was hoping to hear around 800Hz, anecdotally and that sounds about what I've got. Thinking I'll make the baffle to get a little diffraction peak around 800Hz before rolling off and cross her over right about there.
                Dan
                Tall Boys
                NRNP Computer Sub
                The Boxers
                The Hurricanes
                The Baronettes
                Conneccentric
                UX3
                  The MDM55 is a great driver when it's crossed properly and performs very well up to about 5 kHz. In my canTiLenas it's mated with a Fountek Neo CD1.0 and crossed at~ 4.8 kHz. There is something very magical about this mid/tweet combo. Good luck with your project.
                  Paul
                  Dan
                    Paul
                    I have a Neo X 1.0 that I'll use on top. The only problem is I have the silver face tweeter. I might have to see if I can pull the face off and paint it unless someone wants to swap me for a black face model.
                    Dan
                    Tall Boys
                    NRNP Computer Sub
                    The Boxers
                    The Hurricanes
                    The Baronettes
                    Conneccentric
                    UX3
                      I agree.
                      craigk
                        I crossed it at 900 Hz in my Agendas project. Working with it again in my Cumbres project and will cross right about 900 again.
                        Craig
                          They were really nice in your Agendas
                          craigk
                            Agreed!
                              Paul
                              This begs the question: "How *high* can I / should I cross the MDM55?"
                              Looking at the MDM55 polars, 4.8kHz seems to be awfully high in terms of dispersion. Anything above 3.0-3.5kHz really. But perhaps that gives a BBC dip in the overall power response that is quite pleasant.
