Midwest Audio Fest
See more
See less
Passive Radiator Size
  • Passive Radiator Size
    I'm in the process of making bass bins to go beneath a pair of Natalie P.'s that I made.
    My question is that I am going to use the Dayton RF10inch for the driver, so should I use the 12" Dayton DVC PR or maybe a 15" Stryke PR? The 15 models a bit better, but didnt know if it's overkill, and it will make the box a bit deeper than the natalies so it might look a little wierd.
    ANy suggestions welcome,
    Derek
    Re: Passive Radiator Size
    Provided Link: soundhobby
    Derek,
    The 12" PRs will be fine. I used them with my RSHF 10" subs.
    Hong
    LM4780 Parallel Chipamp
    Sonata Soundbar Project
      > Derek
      The Stryke (Acoustic Elegance) Passives are fantastic. Very low resonance, plenty of Xmax and they look good too. I've used them for PR duties paired with an Adire DPL-12.
      There's really no such thing as overkill. Passives can go non-linear as they approach their stroke limits, so by having a larger area, they don't need to move as much to do the job. If it models up nicely, go for it.
      As far as "weird" goes, will you really notice it looking face on?
        I'm guessing you would need two per sub though.
        "I have not failed. I've just found 10,000 ways that won't work." Thomas A. Edison
          Pete:
          What size cabinet do you have for your Adire DPL 12 and strike Acoustic Elegance PR. I have a pair of Velodyne VAX-1215 that are getting old and I believe the 12 Driver and the Passive have been well used and I was thinking of replacing them.The Velodyne cabinets external dimensions are 18W X 18D X 16.5H. There is also a blocked out area for the plate amp. The cabinets are like new, (a long story), so any info you might provide from your subwoofer would be interesting to look at. I priced the factory replacements from Velodyne and was kind of shocked at the low priced drivers they originally used, $60.00. BTW, the driver fires forward while PR fires downward.
          I was just curious if maybe upgrading to a better driver and PR may bring back the sound they made when I first purchased them. They no longer have the clear punch they once had and if you put much power to them they start sounding pretty bad. If you can supply info on where these drivers and PR are available as well as if you think they would work in these Velodyne Cabinets. I would apreciate it very much.
          Jack Taylor
            > Pete:
            > PR fires downward.
            > Jack Taylor
            My cabinets are certainly larger than yours, at just under 5 cubic feet.
            The problem you have with that type of cabinet is that PRs really don't like being mounted horizontally. They have very loose suspension and will sag dramatically, reducing their usable Xmax quite a bit. If there's any way you can re-orient the cabinet so that both the woofer and PR are vertical, you'll benefit sonically, as well as in the longevity of the devices.
            The DPL12 would work in your smaller box, though not optimally, but they are no longer available. A GREAT substitute would be the RSS315HF from Dayton (PE) and I don't know where you can get a passive as nice as what you can get from Stryke (AESpeakers).
            Here's where you can order the PRs
            <A HREF="http://www.acoustic-visions.com/~aco...ive_radiators/">http://www.acoustic-visions.com/~aco...ive_radiators/</A>
            The RSS315HF is available at Parts Express. It is more than the equal of the DPL in almost every category. You won't go wrong using it for sure.
              Pete since you are familiar with the Stryke 15" PR's, could you give me the O.D. of the speaker? I need to work up the box dimensions (It's going to be 9 inches wide, everything else is up in there air - side firing woofers of course -
              Thanks,
              Derek
                > Thanks,
                > Derek
                The Stryke PRs are 15.25" diameter I believe.
