Results 1 to 9 of 9
    Placentia, CA
    1,074
    Default Toroidal Tranformer Question *PIC*
    Hello all,
    I am interested in this buyout for a LM4780 kit I'm building. Load capacity is 350VA, secondary voltage is 55V + 55V. However, I only need 25V + 25V for my kit. Is there an easy way to bring down the voltage from 55 to 25? Or should I go ahead and buy the 25V + 25V instead? Thanks.
    Hong
    Chicago-ish
    1,547
    Default Re: Toroidal Tranformer Question
    Just get what you need. Unless you run some pretty well heat-sinked regulators, which is the other way. But unless you already had plans for regulation, it won't save you any money.
    North TX
    1,979
    > Hello all,
    > Hong
    A 25-0-25 will give you +/-35V or thereabouts. If you need +/-25VDC, you need an 18-0-18 tranny.
    It can't be done with this particular one, but if you need half the AC volts, you can wire the primaries in series for 220/240V if it's a dual. They run quieter that way, too.
    Injiana
    1,289
    > an 18-0-18 tranny.
    25 x 1.414 = 35 volts.
    18 x 1.414 = 25.5 volts.
    The Caps bring up the rms voltage to peak voltage.
    > Hello all,
    > Hong
    Why not use the 16.2volt secondries
    Placentia, CA
    1,074
    After rectification, I need to end up with 35VDC, so the best thing is to buy a new toroid. I was hoping to save some money with the buyout, but in the end, I still need to shell out $50 for a new toroid. :-(
    Buy two 129-084 25v. That 35volt after rec.
    Wish there were real specs available on those things. Odds are, the 16V ones are lower power
    thin gauge secondaries for powering some low level electronics, while the 50V-0-50V winding would be heavier, and supply the majority of the 350VA total power.
    Or not... since we have no idea what it was originally for.. price is the blessing, and lack of knowlege is sometimes the curse of these buyout things.
    Default Not a toroidal transformer but...
    Provided Link: Surplus Transformer
    Almost 600 VA and 44VCT tranny for $25.
