Results 1 to 3 of 3
    Default Xover 3 impedance
    when i model a crossover in xover3 using a parallel crossover under the impedance window it shows that the net impedance of the speaker system to be the same as the drivers ie if i am using two 8ohm speakers the net impedance is 8ohm with a slight rise at the crossover frequency. I had thought that when you parallel two drivers the net should be half of the ohms 8+8=4ohms. also how much of a rise in impedance over the nominal is okay at the crossover frequency it rises up to over 20ohms how can i level that out
    thanks
    Chicago-ish
    1,546
    Default Re: Xover 3 impedance
    Yup.
    > I had thought
    Yup. If you're paralleling them *without* a crossover.
    > also
    > that out
    > thanks
    Depends on the amp. Solid state amps generally don't have issues with a rise at crossover to 20ohm. A tube amp very likely would be less happy with it. If it's a single clean peak, that's less an issue than some of the bumpier rides through that region that can occur.
    I have found that optimizing impedance while also optimizing frequency response is not particularly simple. You can't *just* flatten impedance though.
    > Yup.
    > crossover.
    > C
    zobel networks!!!!!!!!! come on people.
    jim
